Ford Industrial engine
Rod in MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rod in MN Quote  Post ReplyReply Direct Link To This Post Topic: Ford Industrial engine
    Posted: 26 Feb 2015 at 8:08am
Hi Guy's I'm looking for engine parts for a ford Industrial engine. What is the difference between the industrial engine and one in a Ford car it is a 1.1 liter engine in a OMC Mustang 345 Skid Street ??
Thanks
Rod
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 26 Feb 2015 at 8:17am
Most industrial ford motors were gas 134 CI, 172CI, or 196?CI.  A few applications also used a pinto motor.  Look on the valve cover, should have an ID plate, midway down the side of it, IIRR.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 26 Feb 2015 at 8:18am
Usually, Industrial engines have forged pistons, stellite exhaust valves and a steel crankshaft, etc, etc. They aren't the same, even tho they might look the same to you. In the case of a GM 350 V-8 they even had 4 bolt main bearing caps on the Industrial version.
Fred in Pa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fred in Pa Quote  Post ReplyReply Direct Link To This Post Posted: 26 Feb 2015 at 8:43am
Not sure what is Difference ,They do have 5 Or 3 main bearings .Not all 1.1 have same bores . One of the engine suppliers that I am a dealer for has the parts for them .
Send me a PM with what you need and I can give you price .
Edited by Fred in Pa - 26 Feb 2015 at 6:29pm
nonetheless ,still dead.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 26 Feb 2015 at 8:54am
I would bet the cam shaft / valve overlap and timing are different for a  constant speed motor (2000 RPM)  compared to a car.
Edited by steve(ill) - 26 Feb 2015 at 8:54am
Allen Dilg View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allen Dilg Quote  Post ReplyReply Direct Link To This Post Posted: 26 Feb 2015 at 1:19pm
Hello Rod     Need to know the model?   Have 2 small Ford motors on high crop sprayers.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rod in MN Quote  Post ReplyReply Direct Link To This Post Posted: 26 Feb 2015 at 1:44pm
Allen This is what I got from father in law of the valve cover
HD,P Block,1C
Date-Serial# E1268-100
Build# Z-320-TK5-200
1.1L Ford Industrial engine. What is the difference with ford engines and ford Industrial engine. Parts for the Industrial engines is higher $
and harder to find. NAPA can not find them or get them. Auto engines can find all over ??
Thanks Rod
TramwayGuy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TramwayGuy Quote  Post ReplyReply Direct Link To This Post Posted: 26 Feb 2015 at 4:57pm
I think the 1.1 is a British made engine. Not the same as a Pinto engine that was 2.3L
This page was generated in 0.130 seconds.
