Fixing up my Allis B |
Jay Tee ![]() Bronze Level ![]() Joined: 05 Jun 2025 Location: Maryland Points: 14 |
![]() ![]() ![]() ![]() ![]() Posted: 06 Jun 2025 at 10:36am |
I just brought home a B that has lived a pretty hard life. Some joker slapped a WD decal on there at some point - I'm not sure if it was for comedic effect. I have no idea who manufactured the mower - it looks a lot more burly than the ones I've seen fitted to these small tractors in the past.
I bought it with the Marvel-Schebler TSX154 carburetor in bits - luckily I was able to rebuild it and get the tractor started so I could load it. ![]() Edited by Jay Tee - 06 Jun 2025 at 10:48am |
The big problems are
Governor problems... ![]() |
This isn't my first Allis - I had a CA I regretfully sold 15 years ago. The difference between the CA and B is pretty amazing.
PaulB ![]() Orange Level ![]() Joined: 12 Sep 2009 Location: Rocky Ridge Md Points: 5040 |
Where in Maryland are you? Anywhere close to Rocky Ridge? I have some things you may want to get things straightened out.
Middletown area - just south west of you!
PM sent with contact info.
Removed mag and governor between rain storms... ![]() |
Dropped the governor housing off with a friend who has an amazing machine shop in his basement. He recoiled when I said I would just glue the pivot post in with JB weld. In the meantime, the radiator needs help. ![]() |
I have an early non pressurized B radiator that may be fine as is, or at least need less work than yours.
I gave up on that radiator - the core was full of leaks. I found a reasonably priced new one which I just ordered.
My machinist friend fixed the loose pivot post on the governor housing. I'm really pleased with the result! ![]() |
The engine serial number is CR 51181 PA - from what I can tell this is was from 1941. The tractor serial number is from 1948, so it must have blown up and been replaced with the earlier one at some point. I don't know what "CR" means - I thought the engine serial numbers began with either BE or CE
Yes: The engine serial numbers BEGIN with BE,CE, R or CR, The CR engines were originally installed in Power units. The ending letter(s) designates the compression ratio when it left the factory
Thank you! That kind of info is a bit scarce - but at least I know this isn't the original engine!
Phil48ACWC ![]() Silver Level ![]() ![]() Joined: 17 Jan 2013 Location: Vermont Points: 304 |
I have a good hot spark FMJ Magneto if your interested. It came off my WC and has been totally gone through. Works great. $100 plus shipping.
Edited by Phil48ACWC - 19 Jun 2025 at 5:20am |
