F2 gleaner
Keith49 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Keith49 Quote  Post ReplyReply Direct Link To This Post Topic: F2 gleaner
    Posted: 30 Oct 2017 at 10:27pm
I have an F2 gleaner with a 430 corn head I use for my few ackers of corn for my cattle.While combining corn a loud clicking noise started coming out of the console and the amp gauge pegs from full charge to full discharge. It shuts the feul off with each click. The little 4 cyl diesel usually runs great. I hate electrical issues. Any ideas?
tbran View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 31 Oct 2017 at 12:11am
run a large like #8 jumper wire from one side of the main solenoid terminal to the other and see if it stops. Issue is key switch, loose wire from key switch to solenoid, the solenoid or the ground to the solenoid - one of the small wires.. the other small terminal on the solenoid is 12v from key switch.
DougS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougS Quote  Post ReplyReply Direct Link To This Post Posted: 31 Oct 2017 at 5:58am
Yeah.  I'd also say loose connection somewhere. Check all grounds too.
AC200Puller View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC200Puller Quote  Post ReplyReply Direct Link To This Post Posted: 31 Oct 2017 at 6:22am
Also check it over good for a hot wire that is grounding out if the amp gauge went to full discharge!
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 31 Oct 2017 at 9:15am
I would say a loose connection some where from starter to key switch or key to solenoid on console door.
The solenoid don't shut pump off, the key switch shuts both off. It will start and run without the solenoid.
Also check ground on solenoid.       MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote Keith49 Quote  Post ReplyReply Direct Link To This Post Posted: 31 Oct 2017 at 9:37am
Thanks guys, I'll give these things a try, thanks much
This page was generated in 0.124 seconds.
