Engine break in oil
7060 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 7060 Quote  Post ReplyReply Direct Link To This Post Topic: Engine break in oil
    Posted: 11 Jan 2017 at 8:39pm
I just rebuilt the engine in my 185 and overfilled it slightly with Rotella and put a pint of Lucas in it to keep from scoring a piston maybe. I'm thinking I should probably drain it out though and put some break in oil in to help with ring seating. Ive ran it long enough to circulate antifreeze though it but haven't took it out yet. What's the best break in oil to go back in it?
Dan73 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dan73 Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jan 2017 at 8:52pm
This has been discussed here before I personally wouldn't worry about it. I didn't use any in my d15 gas just normal engine oil. I thing the general response in here was how you run the motor is more important then the oil.
cottonpatch View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cottonpatch Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jan 2017 at 9:09pm
Being its winter and it's a fresh rebuild, I would opt for any diesel oil (rotella, delvac or delo) preferably in 10w-30 weight NOT 15W-40.
'52 CA, '61 D10 II, ‘61 D15, '66 D15II, '63 D17D III, ‘69 170, '73 185 Crop Hustler, '79 185, '79 7000, '77 7040
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jan 2017 at 9:36pm
Put the oil you intend to use in it WITH OUT the Lucas. Any additives like Lucas will prevent ring brake in. A cheap motor oil would be better the first 50 hrs than a good motor oil with additives.       MACK
DougS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougS Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jan 2017 at 4:46am
With today's oils an additive is not needed. In some cases they do more harm than good.
Allis dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis dave Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jan 2017 at 8:11am
You can buy John Deere break-in oil from a dealer. Basically just poor oil to help the rings wear in.
7060 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 7060 Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jan 2017 at 9:04am
My thoughts with the Lucas was that it would keep the cylinder walls lubed up a little more to keep from scoring a piston when I'm working it hard. I will drain it and maybe try the John Deere break in oil. I know some people that use it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jan 2017 at 9:07am
10W-30 NOT synthetic car engine oil for 50 hrs.......not diesel oil, car oil.
Bill_MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill_MN Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jan 2017 at 9:24am
royal purple break-in oil, and NO additives of any kind
Edited by Bill_MN - 12 Jan 2017 at 9:25am
BenGiBoy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BenGiBoy Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jan 2017 at 9:24am
AMSOIL makes break-in oil, if you want to go that route. Only 8.45 a quart. Wink AMSOIL Break-In Oil
'39 Model B
Tractors are cheaper than girls, remember that!
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougS Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jan 2017 at 9:30am
Sayyyyyyyy.. it has that nasty zinc in it, too. :) It's oil without friction modifiers, as I suspected. Many motorcycle oils are also without friction modifiers. As for additives: Buy the right oil in the first place and avoid additives. Most are just snake oil treatments. Even my car owners manual tells me in no uncertain terms to not use oil additives.
Edited by DougS - 12 Jan 2017 at 9:34am
Post Options Post Options   Thanks (0) Thanks(0)   Quote BenGiBoy Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jan 2017 at 9:34am
Sayyyyyyyy.. it has that nasty zinc in it, too. :) It's oil without friction modifiers, as I suspected. Many motorcycle oil are also without friction modifiers.
I thought that older tractor engines needed zinc?
'39 Model B
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dan73 Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jan 2017 at 9:38am
Flat tappers need zinc but this is about the best way to get the rings to cut into the cylinders during the first 50 hours not what is best long term oil for the tractor.   I am in the camp of just run it easy for the first 50 hours with normal oil. Worked on my d15 and I have used that 160 for all it is worth since 1 year of hard farming later runs great. Time will tell how long it lasts.
Edited by Dan73 - 12 Jan 2017 at 9:38am
Post Options Post Options   Thanks (0) Thanks(0)   Quote BenGiBoy Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jan 2017 at 9:40am
So they need zinc, but not in their break-in oil?
'39 Model B
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dan73 Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jan 2017 at 9:48am
Breakin oil is about causing the rings to ware into the cylinders zinc is a lubricant so if you want to focus faster engine ware to get the rings to "take a set" then you need less lubricant in the oil. As I said I am not a fan of break in oil.
Bill Deppe/AC Salvag View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill Deppe/AC Salvag Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jan 2017 at 9:49am
Long time ago an old experienced mechanic advised me to use a 10w or 20w non detergent oil and run for a short time without load as this readily seats the rings
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill_MN Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jan 2017 at 9:50am
Actually, zinc and phosphorus in break-in oil has long-term benefits. As the metal parts wear in together and those microscopic rough spots in metal smooth out, the zinc and phos get incorporated into and coat the wear surfaces which remains once the break-in oil is drained. This helps with wear going forward.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dan73 Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jan 2017 at 9:51am
Bill I think at the time that was good advice but I thing rings and cylinders have come along ways over the years and it just isn't needed any more. But I far from an expert.
Post Options Post Options   Thanks (0) Thanks(0)   Quote BenGiBoy Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jan 2017 at 9:54am
Thanks Dan73, that cleared up some confusion....
'39 Model B
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougS Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jan 2017 at 9:58am
Back in the late 50s Chevrolet told those who bought a car with a 265 V-8 to slowly pour Bon Ami down the air intake to break in the rings. Of course that was when you traded cars every two years anyway.
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jan 2017 at 10:13am
Over the decades breaking procedures have changed. Up until the late 60s Deere suggested a break in oil with Bonne Ami added and to work the tractor as hard as possible. When they changed to chrome rings they left out the abrasive and still worked the engine hard.
In 1973 with a new Ford Pinto (woody wagon) the manual emphasized during the first 500 or 1000 miles varying the engine speed for breaking and not working it hard. That's probably because the rod bearing peak wear point depends on the engine speed and load.
Gerald J.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis dave Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jan 2017 at 11:08am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jan 2017 at 12:13pm
Ben, Doug was being sarcastic........meaning it is GOOD, not nasty.....
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jan 2017 at 12:14pm
I toured the Harvey engine plant back in August of 1980. Engines were connected to a dyno (multiple dyno's and multiple engines in one room) and engine was fired up. Oil pressure was verified. Oil leaks were looked for. I suppose it was allowed to reach operating temps and THEN THEY POURED THE COALS TO IT!! engines were under full load minutes after fire up, and I doubt very much any special oil was used.
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jan 2017 at 12:27pm
oil of today is much better than even just 5 years ago. The break in oil allows a small amount of wear to occur on the rings/cylinders. Modern oil is too good, and the rings may have a hard time seating. Like Dr Allis says, I'm ok with running it for a few minutes, to ensure it's ok, then work it hard for a few minutes, then cool down, and repeat. My pulling engine, and drag cars get broken in with hard use right out of the gate. I am trying the JD break in oil for the first time on an Oliver I'm putting back together. It will not get worked very hard, so I want it to get broken in right. I want to put it on the dyno for a while also.
randy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote randy Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jan 2017 at 12:38pm
John Deere puts 10w 30 break-in oil in all of its new engines, so a JD service manager told me. I think they want it in an engine for about 200 hr, then go to there regular oil.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TimNearFortWorth Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jan 2017 at 1:16pm
Although oils have been changing constantly in the last 5-10 years, changes were implemented in 2016 by manufacturers so as to meet new standards set out to take effect by uncle sam this past December (Sulphur/zinc). I will continue with T1 Rotella from Wally World in my gas units as it is economical and a decent basic oil. Per my machinist who built the last gas engine I had done, he runs 4 oz. of Lucas TB Zinc Plus in everything he builds as a break-in supplement (every day rebuilds up to his own alcohol pulling engines) and advised he has done it this way for years.
When asked specifically if he would recommend any type of zinc additive on older flat tappet units, he advised 4 oz. in every oil change is what he is recommending to his customers.
Take it for what it's worth . . . .
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougS Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jan 2017 at 11:32am
You might want to read this before you just start dumping zinc into your motor oil:
http://www.drivenracingoil.com/news/dro/training-center/articles/zinc-in-motor-oil/
If I wanted zinc in my oil I'd buy oil that already has zinc in the formulation. Make note of what the author says about break-in oils and zinc
Edited by DougS - 13 Jan 2017 at 11:33am
Stan IL&TN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stan IL&TN Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jan 2017 at 12:40pm
That article made perfect sense until they gave the sales pitch at the end for Joe Gibbs assembly lube and oil. But what I did take from that article is that unless it's a high performance engine you can use regular oil off the shelf for break in and normal use and you will be just fine.
1957 WD45 dad's first AC
1968 one-seventy
1956 F40 Ferguson
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jan 2017 at 3:18pm
BINGO - Stan.
