Electrical question |
captaindana ![]() Orange Level ![]() Joined: 14 Sep 2009 Location: Fort Plain, NY Points: 2572 |
![]() ![]() ![]() ![]() ![]() Posted: 18 Jun 2012 at 7:15pm |
Guys I would love to use my C to spray hayground instead of the 4 wheeler. C is stock 6 v and sprayer is 12 volt. But I may just get a pto setup. Ideas?
Mike56073 ![]() Silver Level ![]() Joined: 14 Nov 2010 Location: New Ulm Points: 154 |
Use the 190 instead. Then you have a radio too!
OOps I forgot the 190 is down, but you get my drift.........
Cant really think of any other options other than maybe rigging up a Pto driven alternator?
Dnoym N. S. Can. ![]() Orange Level Access ![]() ![]() Joined: 03 Oct 2009 Points: 544 |
how long would just a remote battery
last ? just an Idea B:-) Dnoym |
bauerd44 ![]() Silver Level Access ![]() ![]() Joined: 11 Sep 2009 Location: Wentzville, MO Points: 350 |
I use my CA to spray weeds in the fence line using a 15 gallon tank sprayer that has a small 12 volt pump. I have a 12 volt battery I keep for that spray job and for a 12 volt fence charger I use around the garden at times. I keep it charged up with a trickle charger.
I can spray weeds for 1 1/2 - 2 hours on a single charge. Works just fine for me.
Missouri Allis-Chalmers Club
CA Allis, 175 Allis, 185 Allis |
Steve in NJ ![]() Orange Level Access ![]() ![]() Joined: 12 Sep 2009 Location: Andover, NJ Points: 12000 |
Cap,
How much amperage does the sprayer need? If not a lot, you could switch over to a 12V Generator & VR to handle the charging chores and keep the Battery happy while using the sprayer. Done deal. I have a 6V Gennie converted to 12V ready to go on the shelf. Max. output 42 amps. Should be more than enough to do the job for headlights, tailight, & sprayer. Change out the 20/20 sweep ammeter to a voltmeter or a 60/60 sweep ammeter for safety. Loose the Headlight/charging switch, (they don't like 12V) and install a fused 12V Headlight switch. If its Mag fired, yer' done. If its Distributor fired, you need an Ignition switch and a 12V/3.0 ohm coil also to control power. We can fix ya up if you want to go that way....
