ED-40 Oil Filter
INV3RSE View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote INV3RSE Quote  Post ReplyReply Direct Link To This Post Topic: ED-40 Oil Filter
    Posted: 26 Apr 2022 at 12:09pm
Does anyone know what engine oil filter is in the ED-40?
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 26 Apr 2022 at 12:20pm
you have the RIcardo 2.3 diesel motor ... right ?
Edited by steve(ill) - 26 Apr 2022 at 12:21pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 26 Apr 2022 at 12:26pm
Your filter is a steel canister with a replacement element inside ???
Edited by steve(ill) - 26 Apr 2022 at 12:30pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote INV3RSE Quote  Post ReplyReply Direct Link To This Post Posted: 26 Apr 2022 at 12:38pm
Thanks Steve, yeah that looks right.
Il see if they ship to the UK and if so how much.
Also, do you know what oil to use? One website says 10w30 and another says 15w40.
Not sure what’s going to be best?
Cheers
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 26 Apr 2022 at 9:26pm
you might GOOGLE or check local auto store for  "LF684" filter..  there may be a "cross reference" to something similar in England...
Most people in the STATES that have diesel engines use 15W40.... Nothing wrong with the 10W30 ... a little better if you have colder weather........  15W40 is specifically a DIESEL oil... 10w30 in the STATES can have a "Cx"  for diesel motors or a SF ( SH, SG, SJ... etc) if it is a gasoline motor..... Make sure you get the  "C-" spec if you use the 10w30.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 26 Apr 2022 at 9:37pm
Edited by steve(ill) - 26 Apr 2022 at 9:41pm
