dye hydraulic fluid
AC WD45 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC WD45 Quote  Post ReplyReply Direct Link To This Post Topic: dye hydraulic fluid
    Posted: 03 Jul 2012 at 11:07am
Always had a hard time reading the dip stick because the fluid is clear. Would if be safe to add a toutch of food coloring to my fluid to make it easier to read?
German Shepherd dad
1957 Allis Chalmers WD45
#WD234847
1951 Allis Chalmers WD
#WD88193
Adam Stratton View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Adam Stratton Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jul 2012 at 9:52pm
I have heard that they make special dye for oils.  When we switched oil suppliers, the new supplier's 821 compatible oil is very light colored and nearly impossible to see in the sight glasses of the 7000 series tractors.  The salesman (from Universal Lubricants) promised to get me some dye, but I aint seen any yet (and that was 3 years ago!)
Ray54 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ray54 Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jul 2012 at 10:19pm
The red dye put in diesel fuel to make off road fuel should work if you could get some.
Ray
ctbowles58 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ctbowles58 Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jul 2012 at 10:31pm
in missouri MFA OIL CO. has purple hyd oil it looks like grape juice.
190XT 2WD45 WF D15 D14 CA BIG10 302 & 303 bailers 77G rake 80R mower 6 plows and alot more
H Clark View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote H Clark Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jul 2012 at 7:13am
Yes they do make dyes for oil. I have used some from caterpillar. The Cat part number is 9u 5032 that is blue. I know that they make other colors also that is just what I have on my service truck. It is very concentrated an little bit will dye alot of oil.
1960 D-12,1948 WC, 1973 160, 1977 175, 1984 6060
DaveKamp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jul 2012 at 5:59pm
Many fuel dyes are incredibly carcinogenic and dangerous to handle.
One way you can get the dye result, is to dump in a bottle of common ATF- it already has dye, and won't adversely affect the hydraulic fluid.
