Do It Yourself Weights - On a Budget Too
Play Farmer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Play Farmer Quote  Post ReplyReply Direct Link To This Post Topic: Do It Yourself Weights - On a Budget Too
    Posted: 19 Apr 2016 at 9:45pm
I'm about finishing up the "field grade restoration" (new paint, fluids, various upgrades, etc - a decent looking work tractor) and needed some front weights.
Locally they're about as rare as hens teeth. Obviously freight is an issue if you buy them on-line. I made the weight for my D17, but they were pretty straightforward. The 7000 took a little design work.
After 3-4 sketches of ideas I finally settled on the final design. Off to the metal shop for a few pieces cut and bent, then home for a bit of welding. I think it will be OK.
This added about 425 lbs, total cost $175.00 and a few hours of garage fun - around $0.41/lb.  If you need more weight just get the cut and bent pieces a little bigger. A few inches either way adds a lot of extra weight.
About 1/2 way welded up;
All welded up, lots of rebar;
Before;
Installed on the tractor;
CrestonM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 19 Apr 2016 at 10:13pm
Filled with concrete I suppose?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Play Farmer Quote  Post ReplyReply Direct Link To This Post Posted: 19 Apr 2016 at 10:14pm
Oh yeah, I failed to mention that part. Embarrassed
SHAMELESS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SHAMELESS Quote  Post ReplyReply Direct Link To This Post Posted: 19 Apr 2016 at 10:29pm
nice looking tractor, shop, and pop up camper! lol
Post Options Post Options   Thanks (0) Thanks(0)   Quote Play Farmer Quote  Post ReplyReply Direct Link To This Post Posted: 20 Apr 2016 at 7:42am
The camper is good. We're heading out in it in about an hour too - headed to Richmond for the NASCAR Race.
On the weight, this is how it's mounted. I ran (3) bolts through the factory weight plate into the C channel, shown above, with the nuts welded on the back side. I don't think it's going to move a bit.
The bolt holes you see on the side are there for lifting. I ran 1/2" eye bolts in both sides, attached a chain and used an engine hoist to lift and mount it. Worked like a champ. The installation took me about 10 minutes, working by myself.
Now I just need to get the rears loaded and it should be ready to work.
Edited by Play Farmer - 20 Apr 2016 at 7:45am
macvette View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote macvette Quote  Post ReplyReply Direct Link To This Post Posted: 21 Apr 2016 at 10:23pm
Good job!
AaronSEIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AaronSEIA Quote  Post ReplyReply Direct Link To This Post Posted: 22 Apr 2016 at 5:48am
Sharp!!!
AaronSEIA
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 23 Apr 2016 at 9:07am
NICE!!
JPG AUSTRALIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JPG AUSTRALIA Quote  Post ReplyReply Direct Link To This Post Posted: 23 Apr 2016 at 6:31pm
very nice looking tractor and great job on the weight box.
