Do I have to drain the oil???
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Topic: Do I have to drain the oil???
    Posted: 23 Oct 2016 at 8:21pm
In the next couple of weeks I am going to be replacing the outer axle seals on my 190XT and the rockshaft bushings and seals as well.  Will I need to drain the transmission or final drive oil for either of these jobs?
Appreciate the feedback.  Hoping I don't have to drain either one, but don't want to make a big mess either.
chuck (WI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote chuck (WI) Quote  Post ReplyReply Direct Link To This Post Posted: 23 Oct 2016 at 9:38pm
I didnt and I replaced axle seals on 3 of em and no oil came out no need to drain for rockshaft bushings unless you remove the housing.
Fred in Pa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fred in Pa Quote  Post ReplyReply Direct Link To This Post Posted: 24 Oct 2016 at 6:51am
If the final oil was never drained from time you bought it ,would be a good ideal to drain and put in new .
nonetheless ,still dead.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 24 Oct 2016 at 8:37pm
Thanks fellas.  The final drive and transmission oils were changed a few years back when the transmission was rebuilt, has seen little action since then so I should be in good shape.
This page was generated in 0.116 seconds.
