Distributor conversion lube question
blue924.9 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote blue924.9 Quote  Post ReplyReply Direct Link To This Post Topic: Distributor conversion lube question
    Posted: 21 May 2017 at 3:40pm
Converting my wd to distributor drive. I am wondering what to put in the housing where the horizontal gear and distributor meet? Does it need oil or grease? There is a zerk right next to the compartment. It goes the housing, a shaft and coupler where the zerk is and then the engine front cover.
hi my names dan, I am a young guy. i have a problem, i prefer my tractors orange and my clutches mechanical, thanks for letting me share
Bill_MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill_MN Quote  Post ReplyReply Direct Link To This Post Posted: 21 May 2017 at 5:43pm
Grease in the gearbox at the end, just take the end plate and gasket off and pack some in there. Make sure the cover gasket is good so it doesn't ooze out. If you got a zerk on the shaft housing grease it. If a slotted head plug on top of the shaft there should be a little cavity around the porous shaft bushing that you fill with oil, it will slowly seep through the bushing lubing it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote blue924.9 Quote  Post ReplyReply Direct Link To This Post Posted: 21 May 2017 at 8:22pm
Thanks that's the answer I was looking for. I have a zerk. When I searched there was talk of oil so I wanted to make sure.
