Disc ? How Big for C |
allischalmerguy ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: Deep River, IA Points: 2893 |
![]() ![]() ![]() ![]() ![]() Posted: 02 Jul 2012 at 9:45pm |
How big of a disc would a C pull in Iowa dirt and getting it in the ground?
Thanks Mike |
CTuckerNWIL ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: NW Illinois Points: 22825 |
I have the 6 foot drag disc that Dad got new with the 47 C. He didn't have the C long but when he got the CA he put 13-24's on it so he could stay up on plowed ground to pull the disc. If it was any bigger than 6 foot, I don't think you could disc plowed ground. You could probably pull a little more in cornstalks???????
Ken(MI) ![]() Orange Level ![]() ![]() Joined: 14 Sep 2009 Location: Lansing, MI Points: 619 |
I agree with the 6'. We used to pull an 8' disc with a B in light ground and it was more than what was good for the tractor. I'm probably in the minority on this, but I prefer implements that are toward the smaller end of a tractor's capability, you can always go a little faster, but you can only go so slow when things toughen up.
Dick L ![]() Orange Level ![]() ![]() Joined: 12 Sep 2009 Location: Edon Ohio Points: 5087 |
This 8 foot pull type disc was pulled over many acres with a C.
A six foot would be fine but I sure wouldn't turn down an eight foot disc. ![]() ![]() |
Thank you all for your replies. Dick that is a beautiful disk! What kind is it? Did you restore it?
I pull an 8 foot Fergeson 3 pt disk behind my WD. I am not sure a C could get the traction to pull a 8 foot disk too deep in my ground...but maybe I would be surprised!!! Should a WD be able to pull a 10 or 12 foot disk? What is all you AC experts opions? Pastor Mike |
john(MI) ![]() Orange Level ![]() ![]() Joined: 12 Sep 2009 Location: SE MI Points: 9262 |
I pulled a 8' IH drag disk around in plowed ground with an IH A. Had plenty of power, so I would think a AC C could as well!
BrettPhillips ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: Strasburg, VA Points: 808 |
As long as the cooling system is in good shape, a healthy C does fine with an 8 ft tandem disc. Dual rear wheels would be ideal, but may not be necessary depending on the soil. Mine does well in second gear with an 8 ft JD KBA in most conditions. These little tractors will make your neighbors stare in slack jawed amazement if you set them up right!
Chalmersbob ![]() Orange Level ![]() Joined: 11 Sep 2009 Location: Pennsylvania Points: 2122 |
I pulled a 7 ft disc with my CA with no problem in third gear. I disked a field for a friend and he said I would have to use 2nd gear going up a hill in the field as he had to do that with his WD when he pulled the disc. I pulled right up the hill in 3rd with no problems. I too feel it is better to have a smaller tool then overload the tractor. Bob
wkpoor ![]() Orange Level ![]() Joined: 25 Apr 2010 Location: Amanda, OH Points: 825 |
I have the 8' pickup disc with my CA and it pulls it very nicely over plowed ground.
DennisA (IL) ![]() Orange Level ![]() Joined: 11 Sep 2009 Location: Ridott IL. Points: 2064 |
I pull a 8-1/2" mounted with a "CA" in plowed ground with no trouble in 3rd gear. I put duals on for a much nicer ride in plowed ground. Just keep in mind that a "C" is not a "CA". I have not ever used a "C". Below is a link of me discing with my "CA" in plowed ground. Who ever had this disc before myself put 18" discs on it.
Thanks & God Bless
Dennis |
Thanks. That was a disc that my Dad bought back in the mid to late 1940's. It is an Oliver disc and I restored it winter be for last. I had to make some of the frame parts as well as machining John Deere bearings and spools to fit. I still need to find or machine channel to hold/mount the scrappers. Some pictures of the restore. http://public.fotki.com/DickL/dads-oliver-66/oliver-disc-repair/
Dick thanks for sharing. You really do first rate work! What did you use to clean up the parts? Did you sand blast everything?
