difference between 180 and 190 gas
fst86410 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote fst86410 Quote  Post ReplyReply Direct Link To This Post Topic: difference between 180 and 190 gas
    Posted: 21 Aug 2011 at 8:18am
Hello, new to the forum.  I was just wondering if someone could tell me what the differences are in the engine being that they are both 2500 series engines?  Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 21 Aug 2011 at 8:31am
180 has a smaller carb and runs 200 rpm slower.
Post Options Post Options   Thanks (0) Thanks(0)   Quote fst86410 Quote  Post ReplyReply Direct Link To This Post Posted: 22 Aug 2011 at 11:28am
That's it?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 22 Aug 2011 at 12:22pm
YUP....you sound surprised?
Post Options Post Options   Thanks (0) Thanks(0)   Quote fst86410 Quote  Post ReplyReply Direct Link To This Post Posted: 23 Aug 2011 at 7:50am
A little.  So I can just slap a 190 carb on my 180 and make 10 more hp?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 23 Aug 2011 at 8:03am
And increase the rpm's by 200.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Skyhighballoon(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 23 Aug 2011 at 10:12am
Do you get the 200 rpm's by changing the 180 governor weights to 190 weights, changing a spring(s) or a combination?  Just curious.  Mike
1968 Gleaner EIII w 10' & 330
1969 180 gas
1965 D17 S-IV gas
1963 D17 S-III gas
1956 WD45 gas NF PS
1956 All-Crop 66 Big Bin
Post Options Post Options   Thanks (0) Thanks(0)   Quote fst86410 Quote  Post ReplyReply Direct Link To This Post Posted: 23 Aug 2011 at 10:48am
Alright, where do I locate a Zenith carb for a G2500 190?
KGood View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KGood Quote  Post ReplyReply Direct Link To This Post Posted: 23 Aug 2011 at 12:20pm
You might be able to make your carb. as big as 190's. With a bigger venturi,main and secondary jet.
Post Options Post Options   Thanks (0) Thanks(0)   Quote fst86410 Quote  Post ReplyReply Direct Link To This Post Posted: 23 Aug 2011 at 1:01pm
I didnt know you could change the venturi.
Post Options Post Options   Thanks (0) Thanks(0)   Quote KGood Quote  Post ReplyReply Direct Link To This Post Posted: 23 Aug 2011 at 2:06pm
We did on our marvels for pulling I would think most zeniths would to.
Post Options Post Options   Thanks (0) Thanks(0)   Quote fst86410 Quote  Post ReplyReply Direct Link To This Post Posted: 23 Aug 2011 at 2:48pm
I'll check it out.  Thanks
This page was generated in 0.783 seconds.
