diagram or info on Marvel Schebler TSX-470 on CA
Justin Widlund (IA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Justin Widlund (IA) Quote  Post ReplyReply Direct Link To This Post Topic: diagram or info on Marvel Schebler TSX-470 on CA
    Posted: 04 Jul 2011 at 5:25pm
I took the M/S TSX470 off my CA and I did not pay attention as to how the "float support spring" should go when I re-assemble.  I thought it hooked on to the bottom of the float needle somehow.  Could someone provide me with some service manual diagrams or a good explanation of how this goes back on?  Thanks!
norm[ind] View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote norm[ind] Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jul 2011 at 5:55pm
  you will know when you assemble it just            turn it upside you cansee if right or wrong   dad will know
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jul 2011 at 6:03pm
Here is a pdf file of the carb. There is no "float support spring"in the manual. I'm not sure what you are referring to.
http://www.oldcarmanualproject.com/manuals/Carbs/Marvel-Schebler/MS-Continental.pdf
Post Options Post Options   Thanks (0) Thanks(0)   Quote Justin Widlund (IA) Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jul 2011 at 8:13pm
Thanks for you help.  This piece is hard to explain as I don't think it appears in the manual that you referenced.
It has me puzzled.  I know its purpose is to attach to the "hammer" end of the float needle so it won't stick, but I cannot make it fit anyway that it won't get stuck up in the seat or get crossways.  I didn't pay close enough attention when  I was taking this one apart.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jul 2011 at 9:27pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Justin Widlund (IA) Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jul 2011 at 8:21am
Thanks again for you help Charlie.
