Deutz Allis 385 Planter
orangereborn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote orangereborn Quote  Post ReplyReply Direct Link To This Post Topic: Deutz Allis 385 Planter
    Posted: 25 May 2021 at 10:26am
What is or is not your favorite adhesive for installing unit seed pads?  Thanks....Dale
DanWi View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DanWi Quote  Post ReplyReply Direct Link To This Post Posted: 25 May 2021 at 3:39pm
Its been a long time ago But I think I used silicon adhesive caulk, It may just have been what I had at the time. Probably could get some good 3M stuff from the car parts store.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 25 May 2021 at 6:41pm
Black or yellow 3M weather-strip adhesive. Get things positioned properly to set and cover with wax paper. Install a seed disc and tighten it up. Let dry for a couple of days and peel the wax paper off.
tbran View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 25 May 2021 at 9:14pm
Make sure the metal galvanized ring is flat and clean of old cement.   We do as Doc sez using talc or graphite lightly rubbed on the wax paper and then use talc or graphite to help prevent seed pad wear. Storing the hoppers inside helps life as well.... mice are kryptonite..   A little know item is Landoll made cast aluminum seed hoppers - if anyone finds any in salvage - don't let them go !  We sold probably 50 to retro fit 385's.  A great update..
This page was generated in 0.309 seconds.
