d19 hydraulic line questions
Post Options Post Options   Thanks (0) Thanks(0)   Quote ChuckLuedtkeSEWI Quote  Post ReplyReply Direct Link To This Post Topic: d19 hydraulic line questions
    Posted: 27 Nov 2011 at 9:57am
So, I got the D19 back together.   Previous owner had a front pump mounted on it with a diverter valve by the existing pump.   The front pump was removed by the diverter valve is still there and plumbed in.   Just making sure, but it appears that the two lines that come from the back just get plumbed back into the pump where they are and nothing crazy.   Also, does the hydraulic pump share the same reservoir as the power director clutch on a D19?   Because there is no fluid in the power director right now either and there is a spot on the right side where the dipstick for the pump would be like on a D15/17 etc. but the spot has a plug capping it off, and the dipstick for the power director says check with rams extended.   I would like to get all the lines in the right spot and it all filled up so I can take it for a spin this afternoon and see what else I can find wrong with the rear end/tranny.
1955 WD45 diesel 203322 was my dad's tractor, 1966 D15 23530, 1961 HD3 Crawler 1918, 1966 D17 IV 83495, 1937 WC 41255, 1962 D19 6221
Travis(NE) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Travis(NE) Quote  Post ReplyReply Direct Link To This Post Posted: 27 Nov 2011 at 11:19am
That front pump and diverter valve was a factor dealer installed option for the 19's. I have a partial set up on mine. If you do end up removing the diverter valve I would be interested in the parts.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Travis(NE) Quote  Post ReplyReply Direct Link To This Post Posted: 27 Nov 2011 at 1:52pm
Sorry I was in a hurry to get to my nieces 5th birthday party and didn't answer the Hyd reservoir question. Yes the PD and Hyd are the same reservoir on a 19 similar to the later 17's.
