D-19 engine swap |
BPM75
Joined: 11 Jun 2011 Location: Greenup IL Points: 1050 |
Topic: D-19 engine swapPosted: 11 Jun 2011 at 5:56pm |
I have recently got a d19 gas in pretty rough shape the motor is stuck and has many parts missing, but the tactor has fas factory 3pt that is complete, what i want to do is make this tractor a diesel,I have found a couple of 262 diesels from d17s but also found 301 from a combine, my question is will the 301 bolt up to the d19 tractor or how much modification will i have to do? Just thought maybe someone has already tried this, i would be greatful for any help or info. Thanks
E7018
Posted: 11 Jun 2011 at 6:11pm |
I put a 301 in a D17 gas series 1. Pretty easy swap. It will bolt up. I had to modify frame rails. The clutch and housing was fairly easy, 190 clutch.
BPM75
Posted: 13 Jun 2011 at 6:44am |
Thanks for the info, if I can get it bought right I think ill try it.
Sandknob
Joined: 12 Sep 2009 Location: Oblong, IL Points: 2456 |
Posted: 13 Jun 2011 at 7:24am |
If you junk the 262 please let me know I need a governer from a D19 gas
Thanks
Adam
BPM75
Posted: 13 Jun 2011 at 6:41pm |
Ill let you know when i get it off
Matt MN
Joined: 14 Sep 2009 Location: Silver lake MN Points: 1491 |
Posted: 31 Oct 2011 at 10:09am |
Are you still looking for a diesel conversion motor?
I have a Nissan diesel motor that is in a D19 tractor. It is rated at 90 Hp, It runs excellant, has all mounting plates, fits very nicely. |
Mottwelding
Joined: 18 May 2016 Location: Fort St.John Points: 35 |
Posted: 22 May 2016 at 8:17pm |
hey did you ever sell that engine and adaptor plate?
