d19 compression
bradley6874 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bradley6874 Quote  Post ReplyReply Direct Link To This Post Topic: d19 compression
    Posted: 21 Nov 2011 at 4:22pm
ok my 19 was smoking real bad bulled the injectors at least 2 bad so there on the way to the rebuilder smarty pants me decided to check comp. all around 200 lbs now i have read my book back and forth and cant find what its supposed to be but that sounds week to me  any help thanks
m16ty View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote m16ty Quote  Post ReplyReply Direct Link To This Post Posted: 21 Nov 2011 at 6:16pm
I'm unsure of the compression but 200 may be about right. 14:1 is the ratio.
You may want to check your energy cells also. They can get full of carbon and cause loss of power and smoke also.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 21 Nov 2011 at 7:04pm
Are you sure 200 is right? I'd swear Dean Byerly told me he was helping someone with a 262 that wouldn't start, the compression was 280 psi, and that wasn't enough. I don't know for sure on a 262, but a Powerstroke won't light off at 200 psi.
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 21 Nov 2011 at 9:55pm
Depends alot on cranking speed. AC service always said to pull one injector at a time and check comp. with tractor running. Alot of extra work. I pull all and check with a good battery charger on batterys.  MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 22 Nov 2011 at 6:33am
You know, sometimes you just simply don't need to know some information. If it ran well enough before, what difference does it make????? there isn't anything you can do about compression numbers without an overhaul/valve job anyway.
DougS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougS Quote  Post ReplyReply Direct Link To This Post Posted: 22 Nov 2011 at 7:51am
Valve problems typically don't show up on all cylinders. If it needs rings, you'd expect to see blow-by from the breather when it is running.
BobHnwO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BobHnwO Quote  Post ReplyReply Direct Link To This Post Posted: 22 Nov 2011 at 11:07am
Amen,Dr.!!
Jeff Z. NY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jeff  Z.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 22 Nov 2011 at 11:14am
But since he is already working on it it doesn't hurt to do some tests to see what condition the engine is in and if a rebuild might be coming soon.
Sometimes a little advanced notice is needed to start saving some money for a big job in the near future.
I Love Meatballs and Dumplings on Toast with Gravy and Rosemary and ??? {Open For Suggestions}
