Print Page | Close Window
d19 compression
Category: Allis Chalmers
Forum Name: Farm Equipment
URL: https://www.allischalmers.com/forum/forum_posts.asp?TID=40903
Printed Date: 29 Aug 2025 at 11:29am
Topic: d19 compression
Posted By: bradley6874
Subject: d19 compression
Date Posted: 21 Nov 2011 at 4:22pm
ok my 19 was smoking real bad bulled the injectors at least 2 bad so there on the way to the rebuilder smarty pants me decided to check comp. all around 200 lbs now i have read my book back and forth and cant find what its supposed to be but that sounds week to me  any help thanks
Posted By: m16ty
Date Posted: 21 Nov 2011 at 6:16pm
I'm unsure of the compression but 200 may be about right. 14:1 is the ratio.
You may want to check your energy cells also. They can get full of carbon and cause loss of power and smoke also.
Posted By: Brian Jasper co. Ia
Date Posted: 21 Nov 2011 at 7:04pm
Are you sure 200 is right? I'd swear Dean Byerly told me he was helping someone with a 262 that wouldn't start, the compression was 280 psi, and that wasn't enough. I don't know for sure on a 262, but a Powerstroke won't light off at 200 psi.
Posted By: MACK
Date Posted: 21 Nov 2011 at 9:55pm
Depends alot on cranking speed. AC service always said to pull one injector at a time and check comp. with tractor running. Alot of extra work. I pull all and check with a good battery charger on batterys.  MACK
Posted By: DrAllis
Date Posted: 22 Nov 2011 at 6:33am
You know, sometimes you just simply don't need to know some information. If it ran well enough before, what difference does it make????? there isn't anything you can do about compression numbers without an overhaul/valve job anyway.
Posted By: DougS
Date Posted: 22 Nov 2011 at 7:51am
Valve problems typically don't show up on all cylinders. If it needs rings, you'd expect to see blow-by from the breather when it is running.
Posted By: BobHnwO
Date Posted: 22 Nov 2011 at 11:07am
Amen,Dr.!!
Posted By: Jeff Z. NY
Date Posted: 22 Nov 2011 at 11:14am
But since he is already working on it it doesn't hurt to do some tests to see what condition the engine is in and if a rebuild might be coming soon.
Sometimes a little advanced notice is needed to start saving some money for a big job in the near future.
I Love Meatballs and Dumplings on Toast with Gravy and Rosemary and ??? {Open For Suggestions}
