D17D pto speed |
randy ![]() Orange Level ![]() Joined: 12 Sep 2009 Location: Illinois Points: 1218 |
![]() ![]() ![]() ![]() ![]() Posted: 27 Oct 2015 at 6:49pm |
When the engine is running at the proper high speed, what should the pto speed on a D17d be? I cant seem to get the reflective tape on the crankshaft pulley to stick. A M&W dyno had a chart that would tell the correct pto speed.
Thanks Randy
jlogli ![]() Orange Level ![]() Joined: 12 Oct 2011 Location: Stockport, IA Points: 862 |
549
1945 WC on full steel, WD wide front, WD45 power steering, 1966 D-17IVfactory 3 point.1967 D-17IV SC. 1973 rotobaler white top. orange top roto, model 90 combine,82S, four bottom plow.302 baler.
So, if my math is correct, when my pto is running 650 rpms, the engine is running 1950?
DrAllis ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Points: 21923 |
540 RPM is at about 1650 engine speed. High idle would be 1950 to 2,000 RPM making the PTO speed in that 650 to 660 range.
Thanks, I had it on a dyno at the I&I show in Penfield a few years ago and they told me i was a little short on rpms. Will check it out tomorrow.
