D17 Tie Rod Ends
79fordblake View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 79fordblake Quote  Post ReplyReply Direct Link To This Post Topic: D17 Tie Rod Ends
    Posted: 19 Dec 2011 at 6:22pm
The tie rods on my neighbors D17 needs replacing. Figured I would go ahead and remove them today since it was pretty nice. I can't remove the nut b/c the ball of the tie rod is spinning. I tried to wedge something in there to stop it and use the impact wrench but was a no go...still spins. Am I going to have to cut the nut off?
I just about finished up the wiring today...cranked it up took it down the road to warm it up good then adjusted the valves. Noticed the temp gauge doesn't work....ill have to add that to the list of things. This thing runs like a top after I did the full tuneup on it. Has tons of power. My uncle rebuilt the engine in it when I was young but hasn't hardly been used since.
B26240 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote B26240 Quote  Post ReplyReply Direct Link To This Post Posted: 19 Dec 2011 at 6:35pm
Sounds like the easy way is to cut off, it's all junk anyway
norm[ind] View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote norm[ind] Quote  Post ReplyReply Direct Link To This Post Posted: 19 Dec 2011 at 7:33pm
  HEAT TO CHERRY RED AN LET IT COOL    IMPACT WRENCH
Post Options Post Options   Thanks (0) Thanks(0)   Quote norm[ind] Quote  Post ReplyReply Direct Link To This Post Posted: 19 Dec 2011 at 7:34pm
   NUT ONLY    SORRY FOR MISQUE
Brian G. NY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian G.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 20 Dec 2011 at 3:16pm
I've had good luck with a "nutsplitter"; those castelated nuts split real easy.
A nice sharp cold chisel will do it also; you don't have to split the nut totally; just enuf so it loosens up.
Orange Blood View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orange Blood Quote  Post ReplyReply Direct Link To This Post Posted: 20 Dec 2011 at 3:36pm
If you are doing the ones up under the bolster, just be careful if you use the blue torch tool, I caught my uncles D19 on fire once doing that.  A diedel fuel leak I didn't see, and a little hay dust make a great fire starter, fortunately I had brought out the fire extinguisher fearing such a problem.
Edited by Orange Blood - 20 Dec 2011 at 3:37pm
Still in use:
TexasAllis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TexasAllis Quote  Post ReplyReply Direct Link To This Post Posted: 21 Dec 2011 at 7:32am
I have an LP burner so I am always leary of using the torch.  A sawzall with a new metal cutting blade made short work of mine.
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 21 Dec 2011 at 8:42am
When I have that problem I use a long crowbar and apply lots of pressure to the ball side of the stud, pressing it in to the arm.  Working alone I slide a pipe over the end of the crowbar and hang some weight to add more pressure.
Then use a boxend wrench to work the nut tight-loose,along with some penetrant.
Gary
Gatz in NE View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gatz in NE Quote  Post ReplyReply Direct Link To This Post Posted: 21 Dec 2011 at 9:22am
Blake,
I have a set of original tie-rod assemblies for a D17 (these are from a SerIV; I think all years are the same).  Ball ends are tight, new zerks, rod-tube slides easily.  Just needs clamp bolts/nuts.  Can send pics if you're interested
Gatz
Post Options Post Options   Thanks (0) Thanks(0)   Quote 79fordblake Quote  Post ReplyReply Direct Link To This Post Posted: 22 Dec 2011 at 12:01am
Gatz, this D17 belongs to the neighbors. Been workin on my stuff the last two days. Goin to tinker on the D17 tomorrow probably and try a few things that have been mentioned for the tie rods.
This thing needs new bakes to....ain't that gonna be fun....how many people think the anchor pin will just fall right out? LOL!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gatz in NE Quote  Post ReplyReply Direct Link To This Post Posted: 22 Dec 2011 at 8:19am
yes...an opportunity to invent new cuss words.
Hopefully, it won't need new drums; which can also test one's patience.
