D17 ser. 4 diesel, left brake locked
wekracer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wekracer Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jul 2017 at 6:44pm
Also I had to cut the pins on my buddies. I used a sawzall and cut near the outer housing then slide the band as far to the outside as possible then cut again leaving as much pin sticking out as possible from the inner housing. I then took a die and started cutting threads on the pin. Once the die hit the housing the pin came out easy. Good luck
Gatz in NE View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gatz in NE Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jul 2017 at 7:22pm
This from the I&T manual.  Can't recall if the A-C manual even has this info for the SerIV
Replace the retractor springs while you're in there.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gatz in NE Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jul 2017 at 7:23pm
Marble17 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Marble17 Quote  Post ReplyReply Direct Link To This Post Posted: 18 Aug 2017 at 8:41am
Well, I just wanted to thanx everyone for advice and support. It's been up and running for a while now.
So if it's any advice to anyone and I know I didn't do it the official correct way, but cheaper. So my drums were completely destroyed, springs, linings, the drum was broken in several places, the only thing that was salvageable was the 4 balls. Bands were in good condition and worked. Outer friction plate was badly scored from broken metal. (I know your all going to cringe here) I used a disk grinder, kept moving and took the scoring out, then 40, 80, 120 to 220 orbital sander and got it smooth. Had to buy 2 shim packs and Had a 1/8" plate cut to a shim, had to grind the three blot heads down a little also. I had to make up .185".... ya I know.
So I did not pull lift arm bracket, took the two bolts off on low side of bands, top pin out, removed, a good shop vac session. Got lucky and brake rod was free and adjustable with some PB blaster.
Bought both brake drums, springs, used the old balls, and put together, bought the two return springs for the bands and installed everything.
I know this was not the correct way but was quicker and cheaper. Thanx again to all
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 18 Aug 2017 at 1:16pm
At least now you know how to do it if you have to go back in...
This page was generated in 0.044 seconds.
