D17 Rear Main Seal
bincitybandit View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bincitybandit Quote  Post ReplyReply Direct Link To This Post Topic: D17 Rear Main Seal
    Posted: 05 Jan 2012 at 9:57am
I have the pan off my D17 and was wondering if by chance it is possible to replace the rear main from underneath without having to split the tractor?  My dad said he used to have a special tool for doing this on a Minneapolis Moline U.
ALLIS: B, WC, G, G, D10, D12, D14, D14(NF), D15, D17, D17(NF), D19, D21, D21
MINNEAPOLIS MOLINE: U, U, U(NF), GB
JOHN DEERE: L
FORD: 871 Select-O-Speed
CASE: 600 Combine
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jan 2012 at 10:02pm
No.   MACK
Orange Blood View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orange Blood Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jan 2012 at 6:10pm
No harder than it is to split these ol girls, you will spend far less time in the long run, and it will hold better if you split it, and pull the flywheel.  While you are not really suppose to, at that point you can change the bottom half fairly easy without pulling the pan or the rear main cap down, but you have to be careful you don't glue everything together.  That also depends on how the old one was glued in, some just won't come out in one piece, others that were poorly done, come out fairly easy.
Still in use:
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jan 2012 at 6:59pm
If the upper half of the rear seal has the OEM bolts in it, they cannot be removed without hitting the crankshaft flange. Sooooo, you have to cut them off and replace with shorter bolts if you try it without removing the crank from the engine.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orange Blood Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jan 2012 at 10:01pm
Dr. Allis,
I guess I have always been lucky someone else put shorter bolts in, I never knew the bolts would not clear the crank, I know they wouldn't come out of the seal holder, but once all three are loose, the whole thing comes out.  I can certainly see where longer bolts would preclude the change.
Thanks,
Anthony
Still in use:
