D17 rear end Oil |
Charlie175 ![]() Orange Level ![]() Joined: 11 Sep 2009 Location: Shenandoah, VA Points: 6369 |
![]() ![]() ![]() ![]() ![]() Posted: 29 Jul 2011 at 6:01am |
Series II
I drained the old oil out and need to know what I need to get to replace it. Manual just says 24 quarts Special Allis-Chalmers Oil
Charlie
allisorange ![]() Silver Level ![]() ![]() Joined: 27 Mar 2010 Location: perkins, michig Points: 381 |
80/90 wt. oil in the rear end.
John Carlson
thanks!
Charlie
Hyd. wet brake oil. agco 821 JD 303 IH Hi tran or any good brand. Much better than the old type of oils. MACK
Mack, are you using the same oil for the hydraulic and power director?
Charlie
Yes use the same oil all the way through. No reason not to use it in final drives also. All the newer tractors use it in final drives (planitary now) on most. MACK
