D17 hydraulics |
Rick1263 ![]() Bronze Level ![]() ![]() Joined: 08 Apr 2020 Location: Il Points: 4 |
![]() ![]() ![]() ![]() ![]() Posted: 25 Jun 2020 at 5:52pm |
I only have one hydraulic port on the back of my d17 looking to make hay using a haybine and square baler I need two hydraulic hookups for each of those units I only have one how will this work?
Edited by Rick1263 - 25 Jun 2020 at 5:53pm |
Joe(TX) ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: Weatherford. TX Points: 1682 |
If they are single acting cylinders, use a selector valve to switch between the cylinders.
Adding a double valve is also an option. The operators manual shows each setup.
DSeries4 ![]() Orange Level ![]() ![]() Joined: 12 Sep 2009 Location: Ontario, Canada Points: 7519 |
Early D17s (prior to Series 4) only have a high pressure/low volume single acting hydraulic system. Not great for what you are wanting to use it for.
