D17 diesel liner protrusion fix? |
Wes (VA) ![]() Orange Level ![]() Joined: 12 Sep 2009 Location: Elkton, VA Points: 510 |
![]() ![]() ![]() ![]() ![]() Posted: 17 Jun 2020 at 9:07pm |
My 17 is in need of this. Just wondering how its done? New liners and cut the counterbore wider? I dont remember a lot of space between counterbores for this last time I had the head off.
Surface block then recut counterbore. My fire rings will stop that problem. MACK
Ok, what gaskets do you use your fire rings with? I put one headgasket on where I had to put fire rings in the gasket. Ive put 2 headgaskets on this tractor. The last one I could see the difference in sleeve height, but like a dummy slapped a new one on and went. I suppose new sleeves are in order to make all this worthwile.
DrAllis ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Points: 21408 |
The original fix from A-C was so sell you new sleeves that had a top flange that was .030" taller/thicker than the original sleeves. You counterbored the block deeper so these new sleeves would stand out at the correct height. This of course meant a complete engine teardown to the bare block to do this.
The Agco, unless the newest have changed. How deep have they sank? If not too much, these MIGHT hold. Measure the thickness of fire ring that failed. MACK
DonDittmar ![]() Orange Level ![]() ![]() Joined: 15 Sep 2009 Location: MIllersburg, MI Points: 2505 |
I have to do my 19D too. I need to get a set of "MACK" fire rings
1968 D15D,1962 D19D Also 1965 Cub Loboy and 1958 JD 720 Diesel Pony Start |
So MACK, when resetting the counterbore, do you recommend the .002 protrusion like the manual calls for, or should you jump to like .004?
Two should be enough. MACK
How do you want us to contact you to order the fire rings
Send a PM or call 660 663 9173. MACK
When I get a minute, ill pull it down and check it out. Got your number saved.
brettssac ![]() Bronze Level ![]() Joined: 09 Feb 2015 Location: alabama Points: 60 |
Mack’s fire rings work thanks again mack
BX2,IB,WC,D15IG, D15IIDX3,D17DI,IID,IIID,IVD,D19DX3,D21II,HD3,185,AND GOD ONLY KNOWS THE EQUIPMENT
