D17 clutch shaft lip seals.
ironac View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ironac Quote  Post ReplyReply Direct Link To This Post Topic: D17 clutch shaft lip seals.
    Posted: 17 Jun 2012 at 7:17pm
I accidently put both lip seals faceing the rear of the tractor and the book says to have them faceing eachother. Will it be ok?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jun 2012 at 8:12pm
If you're talking about the foot clutch seals, both should be facing rearward (spring towards the rear).
BrettPhillips View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BrettPhillips Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jun 2012 at 8:32pm
 Or are you talking about the seals on the transmission input shaft right behind the Power Director clutch pack?  If you want to keep the transmission and PD fluids separate, it might be important...  Some folks leave these out and treat the transmission, PD, and hydraulic compartments as one.  If you have a PD filter like the Series 3 and later, that's probably OK, but I might be nervous about clutch pack shavings getting into the hydraulic system.
Edited by BrettPhillips - 17 Jun 2012 at 8:35pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote ironac Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jun 2012 at 8:58pm
Yep those are what I'm talking about. As long as it doesn't leak is what matters.
