D17 and Disk Mower or Cut/Ditioner? |
AaronSEIA
Joined: 11 Sep 2009 Location: Mt Pleasant, IA Points: 2577 |
Topic: D17 and Disk Mower or Cut/Ditioner?Posted: 05 Jun 2017 at 8:23pm |
Getting to my last nerve trying to cut a little hay with a sickle mower. Has anyone had any luck running a smaller disk mower or a New Idea 7' Cut/Ditioner on a D17? I have a front pump so hyd wouldn't be an issue. I know not having the independent PTO would not be fun, but neither is what I am doing now. When it works, it is a thing of beauty. When it doesn't it could make the Pope cuss.
AaronSEIA Edited by AaronSEIA - 05 Jun 2017 at 8:24pm |
DiyDave
Joined: 11 Sep 2009 Location: Gambrills, MD Points: 54684 |
Posted: 05 Jun 2017 at 8:45pm |
Look around for a drum mower, I pull a ccm 165 (5.5') with my D-12. They are heavy buggers, so don't go too much wider, or you'll need weights up front...
HD6GTOM
Posted: 05 Jun 2017 at 9:27pm |
New Idea cut-ditioner will be good behind the D17. I pull a 9' one behind mine. I have been mowing hay with a D 17 since 1961, pulling a mounted, 3 point, or pull type sickle mower. I have not had a lot of trouble, gotta keep the sickle sharp and guards in good shape, need a grass board on the outer end of the bar and the grass rod on the inner shoe to keep things form plugging. Good luck with your mowing.
AC720Man
Joined: 10 Oct 2016 Location: Shenandoah, Va Points: 5315 |
Posted: 05 Jun 2017 at 9:28pm |
Dad's D-15 pulls his 9' AC haybine just fine, but we use the 6060 ever since he bought it in 1981. D-17 shouldn't have any problem.
Dans 7080
Posted: 06 Jun 2017 at 5:51am |
I have a New Idea 6' cutditioner in heavy hay it will make a D19 talk. Does a great job but does take some power.
When someone tells you Nothings Impossible, Tell them to slam a revolving door
Hyperpack
Bronze Level Access
Posted: 06 Jun 2017 at 8:18am |
I run a 9 foot CutDitioner with a 190XT S3 and find in heavy clover it takes all the power the old Gal can make. I doubt a 17 would run a 7 foot in heavy hay.
Hyperpack
Harvey/pa
Joined: 11 Sep 2009 Location: York Co. Pa. Points: 1031 |
Posted: 06 Jun 2017 at 9:22am |
I had a 9ft New Idea 299 Mowditioner and used my D17 but the 175 handled it way better. Really liked it but couldn't keep a gearbox in it. Do not know if the cutditioner takes more power...Harvey
JohnCO
Joined: 11 Sep 2009 Location: Niwot Colo Points: 8992 |
Posted: 06 Jun 2017 at 10:31am |
A 7' or 9' diskbine will make you wonder why you didn't get one sooner.
Allis Express participant |
WF owner
Joined: 12 May 2013 Location: Bombay NY Points: 5083 |
Posted: 06 Jun 2017 at 10:55am |
I agree 100%! When I bought my discbine, our plans were to mow with both the discbine and our Hesston Hydra-Swing. After we bought the discbine, we rarely used the Hydra-Swing. The discbine does take some power. I would think a D-17 would be a little small for a discbine.
CTuckerNWIL
Posted: 06 Jun 2017 at 11:42am |
I used to run a half wore out dull bladed cutditioner with the 170 when I worked for a guy that did custom baling. Only ting I ever ran it in was cornstalks. we windrowed with it for the baler.
I'm sure that 9 footer would pull harder in standing hay. |
allisrutledge
Joined: 30 Mar 2010 Location: SurgoinsvilleTN Points: 1361 |
Posted: 06 Jun 2017 at 11:43am |
Your 17 will pull any 7 ft mower conditioner with crimper rolls. I had a cutdishner and you will use more fuel and time than you get from the hay your cutting. If it were me it would be a 7 ft disc mower that you have a dealer near. A mower conditioner will be slower. I'm using a 1320 hesston discbine behind a 6060 and in most hay it's ok. In rye or heavy hay I use a bigger tractor. Just my opinion and good luck, Scott
Gary Burnett
Joined: 11 Sep 2009 Location: Virginia Points: 3122 |
Posted: 06 Jun 2017 at 8:22pm |
I have a NI Cutditioner and in regular hay it'll make the D19 work,that said its about my last choice of something to cut hay with.The only thing I ever found it to be really good for
was to scatter windrows that had been rained on. |
