D15 transmission/differential
yzfarmgirl28 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote yzfarmgirl28 Quote  Post ReplyReply Direct Link To This Post Topic: D15 transmission/differential
    Posted: 15 Sep 2017 at 8:26pm
Have a series 1 tractor with gear jumping problems . Was changes made to transmission, differential and wheel axles on a series ll.Housing and castings same? Looking possible switch out complete and wonder if that's an option.
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 15 Sep 2017 at 9:13pm
Before you buy a different transmission check pinion for broken teeth. MACK
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 15 Sep 2017 at 9:28pm
No transmission or rear end changes between Series I and II models.  I have a D15 with a D14 transmission in it.
AJ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AJ Quote  Post ReplyReply Direct Link To This Post Posted: 15 Sep 2017 at 10:26pm
Series 2 finals are slightly wider than D14s and early D15s.
Can't fix stupid
