D15 power director |
Brad1 ![]() Bronze Level ![]() Joined: 22 Sep 2025 Location: Sparta MI Points: 23 |
![]() ![]() ![]() ![]() ![]() Posted: 6 hours 11 minutes ago at 6:22am |
Hello, 1961 D15, I really need help identifying the partial round ring in the pic. I removed the side cover and found this inside the torque tube. I've looked at the shop repair manual, looked online for a description and see nothing about this ring/spacer/shim? What is it, where does it go, and how do I get a replacement? I need to know more about this before I split the tractor. I have a replacement brass collar and PD shifter fork.
DrAllis ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Points: 22010 |
You're going to have to split it anyway. Is it round wire??? or flat like a snap ring?? I cannot think of anything in that area that is bigger diameter than the shifter for the brass collar.
Hello, neither a wire nor snap ring. It's flat like a shim or a spacer. I can see by the blue RTV that someone has had this split for whatever reason. Have you seen anything like this in the PD clutch itself?
Nope.
