D15 II not running right
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Topic: D15 II not running right
    Posted: 05 Jan 2018 at 12:57pm
Hi. Pops was plowing snow, says that it ether full throttle or idling no in between. Think is governor or carburetor. Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jan 2018 at 2:03pm
If all has been working OK before. Weather might be the culprit, ice or blockage of some kind around linkage. HTH Tracy
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jan 2018 at 2:33pm
I had to install 'side shields' on my D-14 last week. It channels the rad/engine heat to keep engine parts ,like carb, warm...
Side shields were made from old 'election' signs, plastic, corrugated, 1 nut and bolt holds them on !
Troy's been fine ever since !
Jay
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jan 2018 at 9:45pm
Governor may have come apart.    MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jan 2018 at 7:59pm
He had it in the garage so is was warm. Guess thinking back it has been acting up for some time
WD45 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WD45 Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jan 2018 at 8:45am
Check the gas flow at carb. Drain gas tank and put fresh number 1 gas in tank.
Fred Dunlop, G,B,CA, WC,WF, 3 WD45`s,gas, diesel and LP,U,D10 series III, D12,D14,D15 SERIES II,D17 Series IV in Gas and Diesel ,D19 GAS and D21,170 185,210 ,220 an I-600 8070 fwd, 716H and 1920H
dt1050 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dt1050 Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jan 2018 at 7:28am
make sure linkage isn't binding up any were.  the person who had my wd45 before me put a nail in the govoner linkage to the carb, it was to long and was hitting the block when the govoner would try to kick in. dt
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jan 2018 at 7:46am
Ok guys thanks.ill have dad check your those things
LeonR2013 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LeonR2013 Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jan 2018 at 9:42am
Is it over reving when you open it up with no load? If it does, more than likely You have broken weights in the gov. DO NOT start it if it does. Get all the pieces out first. Also check the gov. shaft for slack in the bushing. They'll break brand new ones with a worn shaft and bushings.
