D15 hydraulic/transmission/power steering fluid
Tigertacp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tigertacp Quote  Post ReplyReply Direct Link To This Post Topic: D15 hydraulic/transmission/power steering fluid
    Posted: 04 Jun 2020 at 3:35pm
Restoring a 1965 D15 Series II and changing all the fluids. I've got 10 gallons of Rotella HD hyd/trans fluid for another project that is going to wait. Is it ok to use it in the D15 everywhere except final drive? And I've already got 80w-140 if it'll work in the final drive.
Jim.ME View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim.ME Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jun 2020 at 4:37pm
The Data Sheet for it looks like it should be ok. I don't see the AGCO spec but the JD J20C (Hy-Gard) is one of the ones there.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tigertacp Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jun 2020 at 5:25pm
Here's what i have from a Shell spec sheet
AGCO (Deutz-Allis) Powerfluid 821XL, PF821 Allis-Chalmers 257541
And i take it those specs are updated versions, and backwards compatible, with 249680.
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jun 2020 at 7:19pm
Automatic transmission fluid in the power steering.  Dexron.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tigertacp Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jun 2020 at 7:32pm
I assume Dexron III would be the current replacement for Type A.
Edited by Tigertacp - 04 Jun 2020 at 7:48pm
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jun 2020 at 9:10pm
Use 821 or = in everything except engine.        MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jun 2020 at 9:16pm
Agree with MACK..... you will be fine........... You have to watch the NEW transmission fluids ( auto) compared to the old A or F specs... A LOT of the new stuff ( DEXTRON / MERCON) is VERY SPECIFIC/ Addatives /Synthetic and would not be a good replacement for GENERIC type F or A....... You hydraulic oil would be better for steering.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jun 2020 at 11:42pm
Do like Mack says. I have 821 in everything except the engine on my D17D.
This page was generated in 0.093 seconds.
