Print Page | Close Window
D15 hydraulic/transmission/power steering fluid
Category: Allis Chalmers
Forum Name: Farm Equipment
URL: https://www.allischalmers.com/forum/forum_posts.asp?TID=171735
Printed Date: 04 Sep 2025 at 1:50am
Topic: D15 hydraulic/transmission/power steering fluid
Posted By: Tigertacp
Subject: D15 hydraulic/transmission/power steering fluid
Date Posted: 04 Jun 2020 at 3:35pm
Restoring a 1965 D15 Series II and changing all the fluids. I've got 10 gallons of Rotella HD hyd/trans fluid for another project that is going to wait. Is it ok to use it in the D15 everywhere except final drive? And I've already got 80w-140 if it'll work in the final drive.
Posted By: Jim.ME
Date Posted: 04 Jun 2020 at 4:37pm
The Data Sheet for it looks like it should be ok. I don't see the AGCO spec but the JD J20C (Hy-Gard) is one of the ones there.
Date Posted: 04 Jun 2020 at 5:25pm
Here's what i have from a Shell spec sheet
AGCO (Deutz-Allis) Powerfluid 821XL, PF821 Allis-Chalmers 257541
And i take it those specs are updated versions, and backwards compatible, with 249680.
Posted By: DSeries4
Date Posted: 04 Jun 2020 at 7:19pm
Automatic transmission fluid in the power steering.  Dexron.
Date Posted: 04 Jun 2020 at 7:32pm
I assume Dexron III would be the current replacement for Type A.
Posted By: MACK
Date Posted: 04 Jun 2020 at 9:10pm
Use 821 or = in everything except engine.        MACK
Posted By: steve(ill)
Date Posted: 04 Jun 2020 at 9:16pm
Agree with MACK..... you will be fine........... You have to watch the NEW transmission fluids ( auto) compared to the old A or F specs... A LOT of the new stuff ( DEXTRON / MERCON) is VERY SPECIFIC/ Addatives /Synthetic and would not be a good replacement for GENERIC type F or A....... You hydraulic oil would be better for steering.
Posted By: Brian Jasper co. Ia
Date Posted: 05 Jun 2020 at 11:42pm
Do like Mack says. I have 821 in everything except the engine on my D17D.
