D-15 handle Woods RM-306 |
EPALLIS
Joined: 12 Sep 2009 Location: Illinois Points: 1170 |
Topic: D-15 handle Woods RM-306Posted: 11 May 2021 at 9:07pm |
I have a D-15 Series 1. Currently with no extra weights. I'm looking at a Woods Model RM-306 finishing mower. This attaches to the back of the 3 point and can be raised and lowered with the hydralic lift. Should the ole girl be able to handle her ok? It will just be used to mow around the buildings and such to keep everything trimmed up. Many thanks in advance for any thoughts/current or past experiences!
Joined: 11 Sep 2009 Location: illinois Points: 90676 |
Posted: 11 May 2021 at 9:17pm |
YEP.... D15 is plenty big for a 306.
PaulB
Joined: 12 Sep 2009 Location: Rocky Ridge Md Points: 5271 |
Posted: 12 May 2021 at 6:49am |
I've used a RM306 behind a CA with no problem, so behind a D15 will be a piece of cake.
Trinity45
Joined: 17 Mar 2014 Location: Kentucky Points: 2147 |
Posted: 12 May 2021 at 7:00am |
I would think so, I pull a 6 ft finish mower with a CA, the hills pull me down but outside of that on flat ground I have no problems.
sparky
Joined: 13 May 2011 Location: So. Indiana Points: 1832 |
Posted: 12 May 2021 at 9:02am |
I have two 306’s on two CA’s and they eat grass. D-15 no problem. Let us see your setup when you get it going.
Edited by sparky - 12 May 2021 at 9:02am |
Brian F(IL)
Joined: 14 Sep 2009 Location: Paxton, IL Points: 2733 |
Posted: 12 May 2021 at 9:32am |
You should have plenty of power and lift capacity with a D-15. You might need some front-end weight though. Won't know until you try and lift it and do some maneuvering.
Leon B MO
Joined: 12 Sep 2009 Location: Old Monroe, Mo Points: 2231 |
Posted: 12 May 2021 at 8:54pm |
It will be real easy to turn the steering wheel when the mower is off the ground but you may need the brakes to actually get the front end around. HP not a problem but as said you may want to add some front ballast somehow.
Leon B MO:
Jim.ME
Posted: 12 May 2021 at 9:18pm |
I think you need to worry more about if your RM-306 can handle a D15 than if the D15 can handle the mower as far as power. Also I think lifting it and steering, without extra weight on the tractor, won't be an issue.
Roach
Joined: 30 Jan 2013 Location: Wheeler, IL Points: 280 |
Posted: 12 May 2021 at 9:19pm |
Got a 7 foot Woods finish mower behind mine and have had for several years, no problems.
1937 WC, 1948 G,1954 CA,1956 WD45, 1967 D17, 1937 M crawler, 1963 D-19, 1966 190XT, 1967 D-15, 1948 HG42 Cletrac, 1955 G456 Terra Trac, CAT 10 1928 and CAT 22 1938
AC720Man
Joined: 10 Oct 2016 Location: Shenandoah, Va Points: 5458 |
Posted: 12 May 2021 at 9:30pm |
D-15 won’t even know its back there, our series II shocks me at how it handles big jobs for a tractor it’s size. I doubt that mower weighs over 400 lbs, our 60 gallon sprayer full of spray causes no issue for the 15.
DaveSB
Joined: 04 Aug 2012 Location: mocksville, nc Points: 243 |
Posted: 13 May 2021 at 9:35am |
You want have any problems. Even without weights. I have one on the back of my CA with no weights and it works great.
You will have more tractor than you have mower. You want even notice if the belt starts slipping in thick grass. I ran into that problem when I used It behind my WD45, so pay attention for it to start slipping if you try to mow taller grass than you should be. But my belt was old at the time, but it would never change the rpm of the old 45. Great mowers, good luck. |
1948 C, 1953 CA, 1948 WD, 1961 D-17 Series 2 Diesel, 1939 WC, 1957 D14
DonDittmar
Joined: 15 Sep 2009 Location: MIllersburg, MI Points: 2517 |
Posted: 13 May 2021 at 1:32pm |
We have an RD8400 woods mower and the D15 handles like its not even there
1968 D15D,1962 D19D Also 1965 Cub Loboy and 1958 JD 720 Diesel Pony Start |
modirt
Joined: 18 Jul 2018 Location: Missouri Points: 9397 |
Posted: 14 May 2021 at 10:09am |
So who makes a good finish mower? I ask, as I've been wanting to get one for the D15. Is Woods still made? And/or can you get parts? Neighbor drags around an older Bush Hog he picked up used. He uses it like the other type of Bush Hog.......he ground off some fescue and brush that was getting out of control. Could not believe he did it or that it worked as well as it did. Have also seen a Land Pride that looked like it was pretty well made. Also hear you want one that is rear discharge?
Edited by modirt - 14 May 2021 at 10:11am |
