D14-D15 Starter Swap
AC Man View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC Man Quote  Post ReplyReply Direct Link To This Post Topic: D14-D15 Starter Swap
    Posted: 04 Jan 2012 at 6:24pm
Has anybody tried to replace a 6 volt starter on a D14 for a 12 volt off of a D15? Wondered if starter drive is the same, same number of teeth or what my 6 volt has 10 teeth.
Gary in da UP View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary in da UP Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jan 2012 at 6:41pm
 Compare ring gear tooth count on the AGCO pars site, should work, but I have never tried that interchange.
norm[ind] View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote norm[ind] Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jan 2012 at 7:15pm
  not advisable   D-14 HAS 93 TOOTH RING GEAR  D-15 HAS 1150R 116??  SENIOR CITIZEN MOUNMENT   PUTER AT HOME  ALL FROM MEMORY
Kip-Utah View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kip-Utah Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jan 2012 at 7:18pm
Can the D14 starter drive be installed on the D15 starter?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jan 2012 at 7:27pm
There are two different starter ring gears on the D14.I think there is about 10 or 11 tooth difference between them, I do think one is a 93 tooth though. HTH Tracy Martin
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC Man Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jan 2012 at 7:31pm
I checked Agco site the ring gears are different guess it is not a simple swap.
D-17_Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote D-17_Dave Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jan 2012 at 7:43pm
Without looking into all the details on the parts site, D-14, 149ci engine compared to D-15 149 ci engine verses D-15 160ci engine. Did the teeth number change with the tractor or the engine.
Yea, I can fix that.....
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jan 2012 at 7:48pm
Dave, pretty sure it changed midstream on the D14. Early ones have the expensive ring gear. Later ones are cheaper quite a bit . HTH Tracy Martin
Chalmersbob View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chalmersbob Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jan 2012 at 9:47pm
I think the change came when they changed to 12 volt. I know when I installed a new clutch in the d15, I thought that I would use a D14 flywheel, NO!! Bob
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jan 2012 at 10:06pm
Is there a problem with the original starter? If you just want to go to 12 volts, you don't need to do anything with the starter. Just don't crank on it for long periods of time and it will last a long time.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chalmersbob Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jan 2012 at 10:17pm
When I got my D15 it had a 6 volt battery in it. That is how it was being used.
It turned over just like any 6 volt engine does. It had a 12 volt regulator on it, but I didn't know about the coil and genny so I changed them to to be sure. Bob
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jan 2012 at 10:42pm
I have my D14 6 volt starter hooked up to 12.  Really spins it around good!
WEL(IN&TN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WEL(IN&TN) Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jan 2012 at 5:23am
The early 6 volt D14s had a 93 tooth flywheel gear and a 10 tooth starter gear. The late D14 12 volt tractors had a 116 tooth flywheel gear and a 9 tooth starter gear. Cannot interchange them. The 93 tooth gear sells for around $100.00 and the 116 tooth gear sells for around $40.00. Don't ask why the price difference.
Post Options Post Options   Thanks (0) Thanks(0)   Quote D-17_Dave Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jan 2012 at 3:04pm
Good stuff to know. Thanks for the clarity,
