D-14 rear axle housing mounting holes?
Herb(GA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Herb(GA) Quote  Post ReplyReply Direct Link To This Post Topic: D-14 rear axle housing mounting holes?
    Posted: 20 Nov 2011 at 8:56pm
Our 1958 D-14 has two threaded (approx 5/8" dia) holes, one on front side of axle and other on rear side of axle.  Are these holes for bolts for securing some tractor mounted equipment, or what? Herb
Chalmersbob View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chalmersbob Quote  Post ReplyReply Direct Link To This Post Posted: 20 Nov 2011 at 9:02pm
the rear ones are used to secure the rear brackets for a loader.
Have fun if you plan on using them, they will be full of dirt and gravel.
Bob
RichinWis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote RichinWis Quote  Post ReplyReply Direct Link To This Post Posted: 20 Nov 2011 at 9:20pm
They were also for cultivator brackets, and for certain mower brackets.
Eldon (WA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Posted: 20 Nov 2011 at 10:43pm
Most I've seen were full of twisted off bolts!
ALLIS EXPRESS!
This year:
Post Options Post Options   Thanks (0) Thanks(0)   Quote Herb(GA) Quote  Post ReplyReply Direct Link To This Post Posted: 23 Nov 2011 at 6:46pm
Thanks for the inputs.  I was concerned about using for rear brackets of my loader; sounds as though they are strong enough.  Herb
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 23 Nov 2011 at 7:30pm
Just be sure to 'chase' out the threads and get rid of ALL the 'stuff in there' BEFORE you put bolts  in  AND add a good amount of neversieze as well.
