D-14 Power Director o-ring install?
rrhead(SD) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rrhead(SD) Quote  Post ReplyReply Direct Link To This Post Topic: D-14 Power Director o-ring install?
    Posted: 15 Sep 2012 at 2:01pm
I lost the instructions I had saved to install a new o-ring in my D-14's power director shaft. I have the lever off, oil drained and the side cover removed. If anyone can help me with this it would be greatly appreciated. Thanks, rrhead(SD)
2 WDs,WD45,D-14,D-17,D-19D,180,7020,6080FWA,6080 2wd, 6080 2wd(cab),8050FWA,8550,4W-305,Massey 8250. Gleaner L3, R62 &R65 Agco-Allis 1616H & 1920H, AC 720, Terra-Tiger
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 15 Sep 2012 at 2:18pm
Just inside the cover there is a setscrew/jam nut just like on the hand lever. Remove it and then the shaft can be moved side to side. Works better when in low range?? or maybe neutral.
Post Options Post Options   Thanks (0) Thanks(0)   Quote rrhead(SD) Quote  Post ReplyReply Direct Link To This Post Posted: 15 Sep 2012 at 3:08pm
Thank you Dr. Very much appreciated. rrhead(SD)
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 15 Sep 2012 at 10:55pm
I had to make a wrench to fit the jam nut on mine.  Couldn't get any swing before.
