D14 original headlight question |
Steve(SEMN) ![]() Orange Level ![]() ![]() Joined: 12 Sep 2009 Location: Rochester, MN Points: 836 |
![]() ![]() ![]() ![]() ![]() Posted: 27 Jun 2012 at 2:33pm |
Changed tractor to 12 volt. Does the light separate to change bulb to 12 volt or is there a sealed beam that works to interchange. Its measures about 4 3/4 lnches.
GregLawlerMinn ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: Lawler, Mn Points: 1226 |
I never did find a 12V bulb for my 6V D14 headlights. Ended up getting CA lamps with 12V bulbs. Not original, but close.
Currently have: 1 D14 and a D15S2. With new owners: 2Bs,9CAs,1WD,2 D12s,5D14s,3D15S2s, 2D17SIVs,D17D,1D19D;1 Unstyled WC |
wfmurray ![]() Orange Level ![]() Joined: 13 Sep 2009 Location: Bostic NC Points: 1225 |
Never could find sealed beam for my 14 . Son put 12 volt battery charger to it ,pulled lights to see if it was hooked up. Blew all bulbs except one on dash .Its been blind for several years. I thank that no bulb is discontuied.
TedBuiskerN.IL. ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: Davis, IL. Points: 1959 |
Keep it on six volt, use the correct cables, keep things clean, and problem solved!
DSeries4 ![]() Orange Level ![]() ![]() Joined: 12 Sep 2009 Location: Ontario, Canada Points: 7505 |
I am looking for replacement bulbs as well. No luck so far!
MBwcIll ![]() Silver Level ![]() Joined: 03 Oct 2009 Location: Chapin Ill Points: 175 |
It is hard to explain with out pictures. We enjoy the 12V because we use our toy on a regular basis. I cut off the bulb housing and inserted a halagon bulb on the reflector. That way I can use the original housing and lens and have bright light.
BrettPhillips ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: Strasburg, VA Points: 808 |
Agco had the original style 6V sealed beams about two years ago (last time I checked). Be sitting down when you get the price though! To my knowledge, no other sealed beam will fit these lights.
