D12 Trans/Hyd Fluid |
Jeeper38
Topic: D12 Trans/Hyd FluidPosted: 14 Jun 2017 at 12:18pm |
Just curious what people are using for the hydraulic/transmission fluid. This is in a 1963 D12 series II. Currently running "303" but I always think it seems like a very thin fluid. Maybe it should be. I'm running "303" because that what we used in them growing up.
RMD
Joined: 07 Oct 2009 Location: Connecticut Points: 304 |
Posted: 14 Jun 2017 at 2:07pm |
Original specification for the CA (and I think also for D-10/12) was 20W non-detergent motor oil, which is also pretty thin (but could take a while to warm up in the winter).
polarbear
Joined: 05 Jul 2016 Location: addieville il Points: 331 |
Posted: 26 Jun 2017 at 6:27pm |
put in some lucas
DougS
Posted: 26 Jun 2017 at 6:33pm |
I wouldn't go any thicker, considering the same oil is used in the hydraulic system. Hi Trans is your best bet. I wouldn't use additives of any sort. |
polarbear
Posted: 29 Jun 2017 at 10:00am |
use lucas in final drives and transmissions wre 250 gear oil was what was to be used works great and is a additive for oil won't hurt a bit used it in thje 13 speed truck transmission it run 150 degree cooler this works
Macon Rounds
Joined: 18 Feb 2010 Location: Pittsburgh Pa Points: 2229 |
Posted: 29 Jun 2017 at 3:09pm |
I agreeRear Hydraulic Pump "SHARES OIL" with transmission and differential. Running any kinda gear oil or thick additives increases chances of hydraulic behaviors ..... I would use OEM recommended oil......
Edited by Macon Rounds - 29 Jun 2017 at 3:16pm |
