D10 series 2 vs 3
DaveSB View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveSB Quote  Post ReplyReply Direct Link To This Post Topic: D10 series 2 vs 3
    Posted: 07 Mar 2021 at 4:24pm
I just bought a D10 series 2 and it made me wander what the differences were to the series 3.   The series 2 has a lot of options, mine is an original 3 point hitch.
I also just purchased a complete cultivator set, even the cylinder and all attachments to the tractor off a series 3, not sure if it will work on mine or not, but they are in excellent shape and have been used every year up till this one to cultivate tobacco. He’s retiring and sold me the cultivators, but wouldn’t part with his series 3.
I saw all the different levers on it so it made me wander what all is really different, is there a big difference?
Thanks for your help.
1948 C, 1953 CA, 1948 WD, 1961 D-17 Series 2 Diesel, 1939 WC, 1957 D14
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 07 Mar 2021 at 6:51pm
Oval muffler.....lights on the fenders for S-3.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveSB Quote  Post ReplyReply Direct Link To This Post Posted: 07 Mar 2021 at 6:56pm
Thanks doc, so that’s all the differences? We’re the hydraulics the same, just different levers?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 07 Mar 2021 at 7:36pm
I don't come from an area of any D-10/12 tractors. I think the S-3's had different hydraulic valves over an S-2 model. They also had the optional 8-speed transmission, unless later S-2's had it available.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 07 Mar 2021 at 7:54pm
And the decal, under the gas tank.Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 07 Mar 2021 at 7:57pm
Only s 3 had the range transmission.  IIRR, the hyd pump, mounted on the back, not side(different pump), too.
Also, the mid mount rockshaft for lifting front cultivators was exclusive to s 3...
Edited by DiyDave - 07 Mar 2021 at 7:59pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 07 Mar 2021 at 10:38pm
Front end was different for attaching a front chin weight IIRR. Tracy
Charlie175 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 08 Mar 2021 at 6:04am
2 and 3 hydraulic pump are the same
Fenders are different
Lights moved to fenders on 3
3 had the option of larger tires
Hydraulic levers and draft control are different on 3
Chin weight on 3
Throttle is different design on 3 (Operates reverse of previous models)
Oval muffler and oval cutout in hood on 3
3 point design is a little different where/how it mounts on the support brackets on 3
3 had the optional 2 speed transmission
Charlie
