Cylinder sleeve protrusion
Kddrck View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kddrck Quote  Post ReplyReply Direct Link To This Post Topic: Cylinder sleeve protrusion
    Posted: 25 Jan 2022 at 12:08pm
I'm rebuilding the engine on a model C. We had to mill the top of the engine block. My question is how far above the block should the new cylinder protrude?
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jan 2022 at 12:29pm
.002 - .004 inch   .............. look close at the rods on the pistons.. They are offset as you install on the crank... two of them point different than the other two...
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kddrck Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jan 2022 at 1:38pm
Thank you.
