Convert back to generator, but 12v |
BrianC
Joined: 16 Jun 2011 Location: New York Points: 1619 |
Topic: Convert back to generator, but 12vPosted: 02 Oct 2011 at 11:04pm |
Model C converted to 12v with alternator in the '80's.
I have the alternator's regulator in the toolbox. The alternator bearings fell apart. I can replace it for cheap. However, I always felt it didn't look right, sort of had remorse about doing it. I have advice from friend to get replacement alternator for $50 and this time paint it orange, then it would look right. He also said what's next, a quest to find stinky leaded gas? Some people just don't understand. Can anyone suggest a 12v generator and alternator combination? |
Coke-in-MN
Joined: 12 Sep 2009 Location: Afton MN Points: 42266 |
Posted: 03 Oct 2011 at 12:25am |
You should be able to find a 10SI Delco alternator for around $10 now or go to the later style which are smaller and higher output. Or look for a generator off 1955 to 1964 GM car or pick-up to find a 12V generator.
the 10SI is internally reguated so easy to wire with just one wire and sensing wire from hot lead to one spade on alt. regulator terminals Edited by Coke-in-MN - 03 Oct 2011 at 12:27am |
Glockhead SWMI
Joined: 12 Sep 2009 Location: South West Mich Points: 2657 |
Posted: 03 Oct 2011 at 8:12am |
lafontaine generator Exchange can rewind a stock gennie for 12 volts.
GregLawlerMinn
Joined: 11 Sep 2009 Location: Lawler, Mn Points: 1226 |
Posted: 03 Oct 2011 at 8:32am |
Using an alternator from a junk auto would probably be the cheapest repair (the 10SI is a good one). These old Allis's don't use much electricity in most cases (most are rarely used at nite, don't have big radios/amps, don't have A/C/heaters/electric cooling fans, etc...and start rather quickly) and a hi ouput alternator is overkill. I like using the generators from the old Chevys (the short style) when upgrading to 12V; looks original (and installs using the 6V gennie bracket and belt) and it will supply enough power to keep the battery fully charged. I also have the electrical shop run the gennie and balance the regulator to it. To retain the original look and to isolate from the weather, I mount the regulator inside the tool box.
Currently have: 1 D14 and a D15S2. With new owners: 2Bs,9CAs,1WD,2 D12s,5D14s,3D15S2s, 2D17SIVs,D17D,1D19D;1 Unstyled WC |
Brian G. NY
Posted: 03 Oct 2011 at 8:45am |
How about a D-17 Generator? I have no idea how much they get for them at the scrap yards but it should look pretty original? |
Bud(WI)
Posted: 03 Oct 2011 at 8:26pm |
Late D-14's & D-15's were 12v positive ground and had the same engine family.
Chalmersbob
Joined: 11 Sep 2009 Location: Pennsylvania Points: 2122 |
Posted: 03 Oct 2011 at 8:36pm |
D-17 genny is too long. I bought one for my D15, but it wouldn't fit in front of the carb.
Bob
