Chrome Stack for wd45 diesel
n7gleaner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote n7gleaner Quote  Post ReplyReply Direct Link To This Post Topic: Chrome Stack for wd45 diesel
    Posted: 30 Jun 2012 at 5:57pm
HI I purchased a chrome stack off of some tractor website but it did not fit in the 45 diesel exhaust system.If you have a stack on your 45 diesel could you share some details on what you did. I would be very interested. Thank you.
deereequipment1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote deereequipment1 Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jun 2012 at 7:42pm
the "gasoline" version I have for my tractor, was ordered specifically for my tractor.
 http://www.steinertractor.com/default.aspx only lists them for gas. Might not be a diesel one available.
Raised on a CA,WD,D10 & D15.
Now, proudly own and pull a WD45 high crop, WD45, WC,
also own a D-10, D-12, G and a CA.
WD45 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WD45 Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jun 2012 at 7:44pm
We run a D17 series I gas muffler on our WD45 diesel.
Fred Dunlop, G,B,CA, WC,WF, 3 WD45`s,gas, diesel and LP,U,D10 series III, D12,D14,D15 SERIES II,D17 Series IV in Gas and Diesel ,D19 GAS and D21,170 185,210 ,220 an I-600 8070 fwd, 716H and 1920H
Acdiesel View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Acdiesel Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jun 2012 at 7:59pm
i bough a stainless for my d19 diesel and the o.d was 3"and it wouldn't fit the turbo elbow so I took it to the guy down the road that does exhaust work and he expaned the end to fit the 3''O.D. elbow.Long story short, if yours is to small you can find someone that has an exhaust pipe expander,if its to big you can buy an adapter (NAPA) if you wont see it over the hood. good luck.
D19 Diesel,D17 Diesel SER.3
2-D14, 2-D15 SER.II WF/NF
D15 SER.2 DIESEL
D12 SER.I, D10 Ser.II
2-720'S D21 Ser. II
Gmc,caterpillar
TomMN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TomMN Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jun 2012 at 9:52pm
My stainless steel pipe came from Thomure Mfg. 491 East 522nd Rd. East Prairie, MO 63845-8806 1-800-527-9954.
I told them how high it should be and what diameter I wanted and what it needed to be necked down to for the inlet.  HTH Tom
XT in pa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote XT in pa Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jul 2012 at 8:08am
TomMn how much was it  and is it polished .
            Shawn
190XT,D17and 7045
Post Options Post Options   Thanks (0) Thanks(0)   Quote TomMN Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jul 2012 at 8:33am
In 2007 it was $127 plus shipping which made it $140.  Here is a link that shows when I first got it.  I had a clamp to a bracket for the two bolts, but the hood would not fit as the clamp had to be too high.  I had the bracket welded to the under side of the pipe where it was reduced down for the inlet; then the hood fit nice.
http://home.comcast.net/~old_allis/ac-wd45d-final.html
I have since bought a Nelson muffler for use at the farm since it is so loud to have the straight pipe on when working.  The muffler cost $164.43 and with tax and shipping it came to $189.70; so either it was inflation since the muffler was purchased in 2012 or the straight pipe was cheaper.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TomMN Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jul 2012 at 8:50am
The Nelson muffler is taller than my other pipe; I ordered the straight pipe at a height that would fit under the garage door.  I had to move the 45 to the other side of the shed with the 12' door now since it no longer fits where it was.  I measured first though so I drove it out before putting the muffler on; otherwise I would have had to install it twice.
Post Options Post Options   Thanks (0) Thanks(0)   Quote n7gleaner Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jul 2012 at 10:17am
Thanks Tom I viewed your website with your WD45 diesel restoration excellent job. I seen your chrome stack but had no clue on how to get in touch with you.  Thank you for the info will be very helpful.
Thanks,
Aaron
This page was generated in 0.053 seconds.
