Checking Hyd Oil Level on a D14 w/loader
nowaktj View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote nowaktj Quote  Post ReplyReply Direct Link To This Post Topic: Checking Hyd Oil Level on a D14 w/loader
    Posted: 29 Jul 2014 at 3:25pm
The dipstick says to check this level with the rams extended.   I read this to mean the rear lift cylinders.   If a tractor has a loader on it, should you also extend those?  Is there a risk that the cavity will overflow with the loader cylinders retracted then (delta in displacement is the rod cylinder).
Please let me know your thoughts.
Thanks
Terry
D19D, D17D, WD, WC, Snobee, #83 Plow, SC Blade, 14' disk, 400 series planter, B , Terra Tiger, M Dozer w/Baker Blade, TL-12, 42S Grader, G
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jul 2014 at 3:44pm
hmmm... now you've got me thinking.....
If the level's fine with the rearlift up , I'd say you're ok......
and
I've seen where others have tied(chained) down the rear lift to force the oil up to the loader only. The chained rear 'looks' like it's fully extended.it also makes the loader run faster as you don't have to wait for the rear to go up.
Some have a valve to direct flow to either front or back(my #3 does) though I've never used it cause I took the loader off(never used it..)
cheers
Jay
Matt MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Matt MN Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jul 2014 at 4:19pm
Those directions were made for the bare tractor only, adding a loader will require more oil, I would just add enough to get it to function correctly, then you can always add a notch on the dipstick for the new level that is needed for the loader.
ctbowles58 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ctbowles58 Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jul 2014 at 4:58pm
I have a book on my #90 loader and it says add 1 extra qt. with the loader on.
190XT 2WD45 WF D15 D14 CA BIG10 302 & 303 bailers 77G rake 80R mower 6 plows and alot more
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jul 2014 at 5:07pm
I wouldn't fill it with the loader up. You  might end up with oil all over your clutch and pressure plate.
 I have had my 45 for over 30 years and always has the loader on it(well almost) . I have never filled  above the full mark when the lift arms are up.
 I also never chained my lift arms down because when using the loader, they stay up. There is no waiting for them, before the loader comes up. If your lift arms drop down without any weight on them, you will soon be leaking too much oil out the packing. When properly set, the packing in the lift cylinders will keep them up .
Stan R View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stan R Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jul 2014 at 5:10pm
I would think that if you have two way pistons, the oil level would not change (much) in any position.
