Changes to D-14 in 1959 and after?
Tracy Jones View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Jones Quote  Post ReplyReply Direct Link To This Post Topic: Changes to D-14 in 1959 and after?
    Posted: 10 May 2017 at 12:42am
Wondering if a knowledgeable member could describe the changes made to the D-14 in and after 1959? Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 10 May 2017 at 5:03am
Grille was changed to match the new D-10/12 tractor line...
dt1050 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dt1050 Quote  Post ReplyReply Direct Link To This Post Posted: 10 May 2017 at 5:19am
I think they changed the crank shaft pulley.  If I 'm right (rarely) some time in late 59 they started to put a pulley with holes in it for running a hydro pump.  I have a 1960 So I'm interested to know what changes were made also.  I also think that's when they started making them 12 volt negative ground.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 10 May 2017 at 5:56am
went to 12 volt...ring gear and starter have different # of teeth(don't ask HOW I KNOW that one....) but starters WITH a band near the end are 6 volt, NO band = 12 volt.
Fred in Pa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fred in Pa Quote  Post ReplyReply Direct Link To This Post Posted: 10 May 2017 at 6:06am
Steering wheels
nonetheless ,still dead.
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 10 May 2017 at 6:30am
Did the drawbar change some? Like the D17 changed
Wink
I am a Russian Bot
Steve(SEMN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve(SEMN) Quote  Post ReplyReply Direct Link To This Post Posted: 10 May 2017 at 7:04am
1. steering wheel
2. steering wheel shaft
3. 12 volt system
4. longer pto lever
5. wider draw bar bale
6. mesh grill vs black bar grill
7. headlight shape
8. 93 teeth ring gear vs 116 teeth ring gear
9. D14 decals
10. Bolts vs studs on adjustable front end
11. Bigger tail lights, not the bullets
12. Four blade vs five blade fan
13. Front crank pulley, no longer having the crank provision
14. New style key starter vs push button
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 10 May 2017 at 7:05pm
Originally posted by Steve(SEMN) Steve(SEMN) wrote:
1. steering wheel
3. 12 volt system
4. longer pto lever
7. headlight size
9. D14 decals
10. Bolts vs studs on adjustable front end (Earlier had bolts - never seen studs)
11. Bigger tail lights, not the bullets (STILL BULLET, but bigger)
(Some earlier models did not use push button - my 1958)
Aside from my updates, very accurate.
DonDittmar View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DonDittmar Quote  Post ReplyReply Direct Link To This Post Posted: 10 May 2017 at 7:47pm
Yeah learned that one myself.......
1968 D15D,1962 D19D
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Jones Quote  Post ReplyReply Direct Link To This Post Posted: 10 May 2017 at 11:06pm
Thanks Everyone!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Jones Quote  Post ReplyReply Direct Link To This Post Posted: 10 May 2017 at 11:43pm
Next question if anyone knows, was a there an operating instructions and parts illustrations manual that showed these changes. Can't find any manuals that go beyond Form TM-137C. Seems like there would be a newer manual showing at least some of the updates?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 11 May 2017 at 7:01pm
No, because there were no major changes to the tractor.  These are all minor things that did not require a different manual..
Calvin Schmidt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 11 May 2017 at 8:12pm
I'm sure there was an operators manual with the Black Bar grill D-14 on the cover. Will check tomorrow.
Post Options Post Options   Thanks (0) Thanks(0)   Quote tomstractorsandtoys Quote  Post ReplyReply Direct Link To This Post Posted: 11 May 2017 at 9:23pm
If I am understanding right they made a factory 12 volt D14? I still have nightmares about stalling a d14 and hearing that six volt starter try unsuccessfully to start the engine. Nothing was worse than telling Dad I stalled it and needed a pull. Once in a while with a few prayers it would start when hot but most time not. The series II D15 on the other hand never failed me at anything. Tom
Post Options Post Options   Thanks (0) Thanks(0)   Quote dt1050 Quote  Post ReplyReply Direct Link To This Post Posted: 12 May 2017 at 3:35am
yes, I didn't know until I bought mine (1960).  I had assumed it was converted to 12v, but found out the changed them over I think I was told lat 1959?  I was going by tractordata, it also said they didn't come with powersteering, but yep they did.  love them 6volts, better start in the first couple rounds or your done...lol
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Jones Quote  Post ReplyReply Direct Link To This Post Posted: 12 May 2017 at 4:59am
Found this on ebay. Can't read the form number, but since I have an original white covered manual that has publication code 257969 and has the Label on the right edge reading: (Prior to Serial Number 19001), I'm thinking there was a such a manual published.
I'll be on the search for it. My Reproduction business goes online next month. So far I have the following ready, a special edition WD operator and parts illustrations manual FORM TM-9 E, a WD-45 operator and parts illustration manual FORM TM-85 D, a D-14 operator and parts illustrations manual combining all of the forms upto TM-137 C, dealers repair parts manual for wd and wd45 tractors dated 1955 and original dealers repair parts catalog for the D14 dated 1961. I also have a complete pdf version of the 2017 AGCO parts catalog (current parts numbers included) for each that will go along with the reproduction parts catalogs for free. 3/4 done with the WD and WD45, WD45 Diesel and D14 Service Manual. No funds at the moment, but I'll be searching for that late model d14 manual.
Edited by Tracy Jones - 12 May 2017 at 5:01am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 12 May 2017 at 8:59am
I have the original white Operators manual.  Form TM-235
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Jones Quote  Post ReplyReply Direct Link To This Post Posted: 12 May 2017 at 9:06am
is that the Late model d14 manual?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 12 May 2017 at 9:30am
Late D-14  Serial 19,000 and up. Form # above.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 12 May 2017 at 9:35pm
Yes, one of the changes mentioned in this post - Over serial number 19001.  My 58 is volt.  My 59 is 12 volt.  Both unmolested originals.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Jones Quote  Post ReplyReply Direct Link To This Post Posted: 13 May 2017 at 12:15pm
Calvin- I sent you a private message. Allow me to make you an offer you can't refuse?
Toddwyo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Toddwyo Quote  Post ReplyReply Direct Link To This Post Posted: 06 Oct 2017 at 12:50pm
Good day - I have been following your posts about changes to 1959, 1960 D-14 tractors. I am looking for a D-14, either year, either fully restored or in good shape that I could have it restored.  I have been wondering about a number of things for those 2 years.  Was the D-14 decal, near the gas tank, in that location for both years? Was the grill black, with horizontal bars across it?  Were both those years essentially the same?  I am not sure from the posts if both years were 6 or 12 volt?
I appreciate any help you might provide.
Thank you
Todd
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 06 Oct 2017 at 6:42pm
D-14 12 volt started at tractor serial 19001, engine serial 149-19070
Gary
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 06 Oct 2017 at 6:51pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Toddwyo Quote  Post ReplyReply Direct Link To This Post Posted: 06 Oct 2017 at 7:08pm
Thank you so much - very helpful.  Would anyone happen to know of fully restored D-14 tractors?  1959 or 1960?  I have seen some beautiful tractors that others have restored.  I'd love to find one.
Todd
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 07 Oct 2017 at 5:39am
Todd
Post a 'Wanted' Ad in the Classifieds section of this Forum:
Start by clicking on Classifieds section, then 'New Topic'
Gary
