Case ih 5100 grain drill |
bobkyllo
Joined: 14 Sep 2009 Location: minnesota Points: 1561 |
Topic: Case ih 5100 grain drillPosted: 10 Mar 2019 at 2:39pm |
So I bought a 5100 grain drill last spring to plant my oats and beans. I love The thing to death except it has no guidance. No markers what so ever. The previous owner did install a couple chains in the front that you're suppose to use. That really sucks to keep looking back all the time. My thought was to add a couple markers.
Does anyone have markers on their drill? This is only 12 foot. |
old farmer
Silver Level Access
Joined: 12 Oct 2011 Location: Sturgis, Mich Points: 341 |
Posted: 10 Mar 2019 at 6:29pm |
Put the chains on a bar on the front of your tractor and have chain just touching the ground. Make it so can make it narrow for road transport like the first 600 no till planters used in the 70s
bradley6874
Joined: 05 Sep 2010 Location: salisbury md Points: 1349 |
Posted: 10 Mar 2019 at 7:28pm |
I used the markers from an old international planter If I was to do it over I. Would set the light bar up to switch tractors for spraying to planter
Edited by bradley6874 - 10 Mar 2019 at 7:43pm |
beard66
Joined: 07 Jan 2013 Location: southern il Points: 45 |
Posted: 10 Mar 2019 at 7:29pm |
I have seen a few with markers, though not very common in my area. We used to pull a 21 hole 5100 with an ih 656 gas. We used a pipe on the front of the weight bracket with a chain hanging from each end that would lay in the drills tire track from the previous pass. Worked great with the flat smooth tires that came on the drill new.
MACK
Posted: 10 Mar 2019 at 10:03pm |
Buy a GPS and use it on every thing, or I will sell you a set of hydraulic markers off my 20 ft JD drill. MACK
Ron(AB)
Posted: 11 Mar 2019 at 10:07am |
Once you get used to how far away to drive from the previous row you just planted, you shouldn't need to look back. We (and most of our neighbours) have the same drill and none use a marker with 12 feet.
20 - 24 feet is when to use a marker. |
