Carbs same on C and CA? |
Hubnut
Joined: 30 Jul 2014 Location: Gainesville, FL Points: 1817 |
Topic: Carbs same on C and CA?Posted: 26 Mar 2016 at 4:39pm |
Are the carburetors for the C and CA identical?
1940 B "Lucy"
1941 B w/ Woods L59 "Flavia" 1942 B w/ finish mower "Dick" 1941 C w/ 3-point "Maggie" 1947 C SFW w/ L306 "Trixie" 1972 314H |
Leon n/c AR.
Joined: 19 Mar 2013 Location: Heber Springs A Points: 177 |
Posted: 26 Mar 2016 at 4:54pm |
B-C-CA carbs will interchange whether Zenith or Marvell-Schebler brand. Leon
Dick L
Joined: 12 Sep 2009 Location: Edon Ohio Points: 5093 |
Posted: 26 Mar 2016 at 5:53pm |
They were not! As stated above they are interchangeable.
Hubnut
Posted: 26 Mar 2016 at 6:36pm |
Dick,
I take it they were different from factory, but would all work despite the tractor model? Thanks. Steve |
1940 B "Lucy"
Steve in NJ
Joined: 12 Sep 2009 Location: Andover, NJ Points: 12071 |
Posted: 26 Mar 2016 at 7:04pm |
The B/C Zenith carbs were in the same family, but when it came to the CA, they had a different carb on them because of the higher rpm range they worked in. They will all interchange, but the CA carb on a B or C might be a tick on the fat side for the fuel ratio because of the different jetting...
Steve@B&B |
Dick L
Posted: 26 Mar 2016 at 7:22pm |
Assuming all models have been upgraded. If you have a low compression 3 1/4" piston engine the carburetor from a CA might not start well with the larger venturi. |
wfmurray
Joined: 13 Sep 2009 Location: Bostic NC Points: 1225 |
Posted: 26 Mar 2016 at 7:38pm |
I got a 49 b to restore and the carb was bad. It did't have a venture.Got one off a C A and bolt holes was wider about one fourth inch .Filed it out to fit .Cranks real good but wants to surg when not pulling a load.
Hubnut
Posted: 26 Mar 2016 at 8:05pm |
Thanks everyone. Do you know the maker of the carb for the CA? Still a Zenith?
1940 B "Lucy"
norm[ind]
Joined: 29 Oct 2010 Location: bourbon,ind Points: 2992 |
Posted: 26 Mar 2016 at 8:20pm |
does yours have a surge spring on it --yes or no if surging
wfmurray
Posted: 26 Mar 2016 at 9:02pm |
It has a surg spring
Alex09(WI)
Joined: 15 Mar 2012 Location: CECIL WI Points: 1777 |
Posted: 26 Mar 2016 at 11:39pm |
Not sure with the zenith, but the Marvel Schebler is TSX154 for b/c/ca. Tractors came with both Zenith and M-S depending on what the factory had on hand at the time. |
www.awtractor.com
A&W TRACTOR 920-598-1287 KEEPING ALLIS-CHALMERS IN THE FIELDS THROUGH THE 21ST CENTURY |
Dick L
Posted: 27 Mar 2016 at 7:27am |
Any that I run across had the Marvell-Schebler
