Print Page | Close Window
Carbs same on C and CA?
Category: Allis Chalmers
Forum Name: Farm Equipment
URL: https://www.allischalmers.com/forum/forum_posts.asp?TID=120969
Printed Date: 26 Aug 2025 at 6:02am
Topic: Carbs same on C and CA?
Posted By: Hubnut
Subject: Carbs same on C and CA?
Date Posted: 26 Mar 2016 at 4:39pm
Are the carburetors for the C and CA identical?
1940 B "Lucy"
1941 B w/ Woods L59 "Flavia"
1942 B w/ finish mower "Dick"
1941 C w/ 3-point "Maggie"
1947 C SFW w/ L306 "Trixie"
1972 314H
Posted By: Leon n/c AR.
Date Posted: 26 Mar 2016 at 4:54pm
B-C-CA carbs will interchange whether Zenith or Marvell-Schebler brand. Leon
Posted By: Dick L
Date Posted: 26 Mar 2016 at 5:53pm
They were not! As stated above they are interchangeable.
Posted By: Hubnut
Date Posted: 26 Mar 2016 at 6:36pm
Dick,
I take it they were different from factory, but would all work despite the tractor model?
Thanks.
Steve
1940 B "Lucy"
1972 314H
Posted By: Steve in NJ
Date Posted: 26 Mar 2016 at 7:04pm
The B/C Zenith carbs were in the same family, but when it came to the CA, they had a different carb on them because of the higher rpm range they worked in. They will all interchange, but the CA carb on a B or C might be a tick on the fat side for the fuel ratio because of the different jetting...
Steve@B&B
Posted By: Dick L
Date Posted: 26 Mar 2016 at 7:22pm
Dick,
Thanks.
Steve
Assuming all models have been upgraded. If you have a low compression 3 1/4" piston engine the carburetor from a CA might not start well with the larger venturi.
Posted By: wfmurray
Date Posted: 26 Mar 2016 at 7:38pm
I got a 49 b to restore and the carb was bad. It did't have a venture.Got one off a C A and bolt holes was wider about one fourth inch .Filed it out to fit .Cranks real good but wants to surg when not pulling a load.
Posted By: Hubnut
Date Posted: 26 Mar 2016 at 8:05pm
Thanks everyone.  Do you know the maker of the carb for the CA?  Still a Zenith?
1940 B "Lucy"
1972 314H
Posted By: norm[ind]
Date Posted: 26 Mar 2016 at 8:20pm
  does yours have a surge spring on it --yes or no  if surging
Posted By: wfmurray
Date Posted: 26 Mar 2016 at 9:02pm
It has a surg spring
Posted By: Alex09(WI)
Date Posted: 26 Mar 2016 at 11:39pm
Not sure with the zenith, but the Marvel Schebler is TSX154 for b/c/ca. Tractors came with both Zenith and M-S depending on what the factory had on hand at the time.
www.awtractor.com
A&W TRACTOR 920-598-1287
Posted By: Dick L
Date Posted: 27 Mar 2016 at 7:27am
Any that I run across had the Marvell-Schebler
