Can I use an adjustable 336 corn head on 30" rows? |
dertz19 ![]() Bronze Level ![]() Joined: 22 Sep 2009 Location: Minnesota Points: 94 |
![]() ![]() ![]() ![]() ![]() Posted: 05 Sep 2025 at 11:07am |
I understand these heads can adjust up to 2"? So that brings it down to 34". 330's are darn tough to find around me, but there's a 336 close by. This is on a K2.
DrAllis ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Points: 21899 |
If your hybrids have the ear up off the ground aways, it would work as you can carry the head raised up a bit. You are bending the stalk inward, which is better than outwards. Certainly not ideal. As far as the 2 inch thing.....a 4-38 head can be made 36 or 40. If it is truly 36 inches, the sheetmetal bolts should be in the middle set of holes. It might be a 3-38 head ?? set to 36 meaning that's it.
Thanks for the input. Good point about raising up the header!
I was wrong. You are bending the stalk outwards. Not a good thing.
dr p ![]() Orange Level ![]() Joined: 24 Feb 2019 Location: new york Points: 1405 |
i have done it with a two row head and its hard. With a three row head, the discrepancy is 18 inches. That won't work. Maybe if you only use two rows but i would keep looking
AC7060IL ![]() Orange Level ![]() Joined: 19 Aug 2012 Location: central IL Points: 3533 |
Dertz19, yes as long as corn is standing good(no root lodged or stalk lodged).
Center drive 336’s middle row spot on & two outside rows are each 6” off centered but snouts should direct stalks into snap rollers. Maybe set cornhead sprocket drive to slower speed & pace combine’s forward travel for best results. Adjacent row(s) maybe get crowded away from outer snout’s rear fenders. Drive so cornheads left side slip-clutch’s metal cover/panel is towards harvested side. It sticks out about 6” from edge of fender. Edited by AC7060IL - 7 hours 1 minutes ago at 6:33pm |
