CA vs D10/12 comfort
KMAG View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KMAG Quote  Post ReplyReply Direct Link To This Post Topic: CA vs D10/12 comfort
    Posted: 27 Mar 2021 at 7:16pm
I climbed on a D10 today. Talk about uncomfortable to use. That steering wheel is huge, low, and near parallel to the ground. It forced me to be bowlegged to drive it as the fenders squeezed me into the seat area. And yes, the seat was bolted to the rear most position.
This is a p/s industrial D10, in case that changes the steering wheel specs.
Unless there is a way to raise the steering wheel height, drop the seat height, and/or reduce steering wheel diameter, the CA is better for us taller guys.
Edited by KMAG - 27 Mar 2021 at 8:13pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 27 Mar 2021 at 9:40pm
I have never been on a D12 Industrial so i dont know.... I have a couple "B" tractors and the steering wheel is TOO CLOSE to the chest for me ( just the opposite of your view).. I have taken the gear box off, taken out the steering shaft, cut out 6 inches and reweld it .. then cut the outer tube off 6 inches.. Works good for me... If this D12 IS factory, it could be extended upward  by adding a few inches.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 27 Mar 2021 at 9:47pm
Here is a picture i took at HUTCH in 2007.... your right..
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 27 Mar 2021 at 9:54pm
Note the HIGH RISE steering wheel on this one..
KMAG View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KMAG Quote  Post ReplyReply Direct Link To This Post Posted: 27 Mar 2021 at 10:58pm
The Industrial D10 is so rare, it seems wrong to modify it to make it useable.
Imho: Extending the steering column would be the best fix.
Side view:
Edited by KMAG - 27 Mar 2021 at 11:02pm
Gary Burnett View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 28 Mar 2021 at 1:16am
The seat is the problem put a metal seat on it off a D10
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 28 Mar 2021 at 5:33am
must've had shorter operators back then ????
curious am I....
what's the vertical lever coming out of the 'wasp house', behind the loader levers do ??
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 28 Mar 2021 at 7:33am
Jay, down here in Joisey we call that a "mouse house".  LOL! I like the " wasp house " version to though... Thumbs Up   BTW, what is that lever for??
Steve@B&B
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 28 Mar 2021 at 7:38am
My first guess is the throttle. because I can't see one anywhere eles that would make sense unless it has a foot throttle?
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 28 Mar 2021 at 7:38am
I believe that is the throttle.
KMAG View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KMAG Quote  Post ReplyReply Direct Link To This Post Posted: 28 Mar 2021 at 7:40am
The vertical lever is the throttle.
Charlie175 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 28 Mar 2021 at 7:41am
That is the Throttle
Charlie
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 28 Mar 2021 at 8:01am
Would that be the throttle??  LOL!  I know.. I know.. wise-a$$!  LOL!  I wouldn't have any problem steering that Tractor. I'd probably have a problem getting up on it to steer it!  LOL!  Most folks know I'm built close to the ground, but that's mainly for speed..... Wink
Steve@B&B
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 29 Mar 2021 at 6:15am
I'm 6' and find the D10/12 easy enough to sit on and have room.  Yes the steering can be a little close. You guys with beerpacks would find it tight.
The CA is OK to sit on but getting on and off that thing can be a pain. The D series is so much better in that aspect.
The Industrial model has so much more going on with the loader frame and controls that is takes up a lot of the space you had.
Charlie
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 29 Mar 2021 at 7:26am
thanks guys ! never occoured to me it's be the throttle, thought the 'industrial' machines all had foot pedal 'togo'.....
Now I can't decide which is prettier.... 'sunday best or working clothes' ?
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 29 Mar 2021 at 7:40am
The throttle / Governor Control Lever is located in the normal D-10 / D-12 location.
It is clearly visible in the last picture above, taken from the R/H side of the Steering Wheel.
You need to slide the picture to the left until the 2 Loader Hydraulic Levers are centered on your screen.
The Throttle Lever is located between the 2 Loader Levers.
G
RMD View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote RMD Quote  Post ReplyReply Direct Link To This Post Posted: 29 Mar 2021 at 12:58pm
I have two D-12s.  The shift in the operator's position from the CA to the D-10/12 certainly involved some compromises.  The main thing that bothers me is that you have to reach through the steering wheel to shift gears.  I was always taught not to reach through the steering wheel, just like you never wrap your thumb under the wheel.  Rough ground/holes can cause the wheel to move suddenly and break your arm/thumb.
KMAG View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KMAG Quote  Post ReplyReply Direct Link To This Post Posted: 29 Mar 2021 at 2:42pm
The D10 Industrial was sold at auction today.
$5,700.00!
https://www.proxibid.com/Allis-Chalmers-L-99-tractor-w-loader-bucket/lotInformation/60319444
KMAG View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KMAG Quote  Post ReplyReply Direct Link To This Post Posted: 29 Mar 2021 at 3:12pm
The Ind D10 seems to have a shorter steering column than the ag D10.
Notice how the steering wheel rim is lower than the seat.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 29 Mar 2021 at 4:03pm
Andy, is it really shorter, or just a big thich padded seat on the Industrial ?  Lower the seat 3-4 inches and it might look the same... but leg room might be a problem with lower seat ? ............... i like raising the steering wheel / shaft 6 inches ??
victoryallis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote victoryallis Quote  Post ReplyReply Direct Link To This Post Posted: 29 Mar 2021 at 5:42pm
But a D12 isn’t synchronized or power shift so your not shifting on the go so how will rough ground get your arm or thumb?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 29 Mar 2021 at 6:13pm
I have a lot of old advertising literature. Every picture I have of a series 3  D-10 or D-12 has the deluxe seat cushion 4 inches below the tops of the fenders. Also, the OEM deluxe cushion isn't as thick as that yellow tractor in the picture.
HD6GTOM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HD6GTOM Quote  Post ReplyReply Direct Link To This Post Posted: 29 Mar 2021 at 6:23pm
One of my fuel customers had a D10. It was the only one I was ever on. At 6'2" it was certainly uncomfortable. I had to move it to get to his fuel tank, only time I ever ran one. Only one I ever saw on a farm.
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 29 Mar 2021 at 7:20pm
In the above picture the seat appears to be in the standing position (up and back) that raises you up under the steering wheel.  Those Deluxe seats have a driving position and a standing position. They can be a very nice tractor and I'd suggest getting the deep dish steering wheel like shown on the I-400 which is also the same as a 190 uses.
Dusty MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dusty MI Quote  Post ReplyReply Direct Link To This Post Posted: 29 Mar 2021 at 7:22pm
I have a D-10  series III with the Hi/Lo ahead of the transmission. I like to partisapate in tractor drives/caravans.
Time is starting to catch with me.
Dusty
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 29 Mar 2021 at 7:30pm
What is the diameter of dished wheel. I think I would like to try one. Thanks Tracy
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 29 Mar 2021 at 9:36pm
It is actually a little smaller in diameter than the flat steering wheel. Same as a 170-180-200-7000 series.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 30 Mar 2021 at 9:29pm
The 170 -175 wheel measures 16 inches. The D10-12 measures 17 1/2 inches. The 170-175 wheel will  raise the rim about 5 inches. HTH Tracy
