CA tie rods
Joe(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe(OH) Quote  Post ReplyReply Direct Link To This Post Topic: CA tie rods
    Posted: 05 Sep 2015 at 8:54am
Need to adjust my wide front out, but my tie rods are stuck. Took them off the tractor used heat and a bfh but can't get them to come apart. Anyone have any tricks to getting them apart? Or what are you guys using as replacement tie rods? Thanks!
Life is simpler when you plow around the stump.
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 05 Sep 2015 at 8:56am
New tie rods are available on the aftermarket.  Lots of heat and oil is needed to loosen up seized tie rods.
wfmurray View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wfmurray Quote  Post ReplyReply Direct Link To This Post Posted: 05 Sep 2015 at 12:00pm
Put penetrating oil on and let soak next use hammer (about one lb)and beat all over . The light beating will make the metal stretch and loosen up .It will take patance.It worked on my B and I had tied it to a tree and pulled it with D14.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 05 Sep 2015 at 8:13pm
Yes lots of PB blaster, heat and I used a pipe wrench to get it to budge (turn) once it moves you got it! Then grind off all the marks and re assemble with some never seize on the stem.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 05 Sep 2015 at 8:43pm
Got one to make a full turn, but it's still stuck! Got them soaking for now.
Josh Day View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Josh Day Quote  Post ReplyReply Direct Link To This Post Posted: 05 Sep 2015 at 9:14pm
50/50 mix of aceatone and ATF, soaked the wide front spindle tubes on a IH 560 with it for a day, came right apart. Or buy a new set lol.
Edited by Josh Day - 05 Sep 2015 at 9:15pm
AC's 75' 7040, 64' D-17S4, 55'WD-45, 54' WD-45, 53' WD-45, 53' WD, 52' CA, 36' WC. IH 656. Deere's 38' A, and 47' A
ctbowles58 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ctbowles58 Quote  Post ReplyReply Direct Link To This Post Posted: 05 Sep 2015 at 10:18pm
when you get them apart and cleaned up, put NEAVER-SEZE on them before you put them back together.
190XT 2WD45 WF D15 D14 CA BIG10 302 & 303 bailers 77G rake 80R mower 6 plows and alot more
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 06 Sep 2015 at 9:21am
Now that you mention it I think I had to use a 2 lb sledge at some point to get it to move out. Just try not to destroy the part your whacking on. I may have beat on the end that is under the tractor just in case the damage was going to be more apparent:)
Yea these are a bugger. I was to cheap to buy an new set. In  fact one was bent and I straightened it too. I think I even shortened the stems a little bit (couple inches).
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 30 Oct 2015 at 7:58am
Had them soaking, still stuck.  I'm thinking about just replacing them but everything I find needs the holes reamed out with a 7 degree taper.  Are there any available that will fit with out modification?
